15:1 a/f = more hp than 13:1???
Old 11-07-2005, 07:05 PM
WS6 GreeN's Avatar
Default 15:1 a/f = more hp than 13:1???
Someone help me out here. I recently dynoed my car and my first pull was 498.9 rwhp with a 15:1 air/fuel. Dangerous, I know. But I had 0 KR. I dropped the air/fuel down thinking I had some power to be gained, but instead, I lost 4 horsepower with a 13:1 air/fuel. Why do you think this would be??? It makes no sense to me. I DID gain torque by dropping the a/f though.
Old 11-07-2005, 08:45 PM
JimMueller's Avatar
I'd rather lose 10-15rwhp and run a safe AFR. There could be other factors which attributed to the 4rwhp difference as well. I personally haven't seen a Dynojet have results within 5rwhp from back-to-back pulls. Doesn't mean it can't happen.
Old 11-07-2005, 08:51 PM
HumpinSS's Avatar
Make sure you have no exhaust leaks prior to the WB
Old 11-07-2005, 08:59 PM
SideStep's Avatar
You may be able to get away with that on a dyno but unless you live in Anchorage doing it on the street is going to pop something... The highest I have ever dared for any extended amount of time was 14.0 (at WOT), but that was mid Winter and my IATs stayed around 30-40 degrees Fahrenheit... and yes it did scream at 14.0 AFR and 28 degrees advance... I stay around 13.6 AFR now, my DCR is 8.3 so I can live with it as long as I see no KR...
Good Luck,
Old 11-07-2005, 09:10 PM
LS1 Tech Administrator
Patrick G's Avatar
If you were sticking the WB sensor up the tailpipe, then that's your problem. Reading A/F ratio that way typically gives leaner readings than what is really taking place in the motor, often up to 1 point too lean. EG, if the motor is making 13.0:1 A/F ratio, it might be reading 14.0:1 at the tailpipe.
In your example, 15:1 at the tailpipe might actually be closer to 14:1 at the motor. You may not be as lean as you think.
__________________
2013 Corvette Grand Sport A6 LME forged 416, Greg Good ported TFS 255 LS3 heads, 222/242 .629"/.604" 121LSA Pat G blower cam, ARH 1 7/8" headers, ESC Novi 1500 Supercharger w/8 rib direct drive conversion, 747rwhp/709rwtq on 93 octane, 801rwhp/735rwtq on race fuel, 10.1 @ 147.25mph 1/4 mile, 174.7mph Half Mile.
2016 Corvette Z51 M7 Magnuson Heartbeat 2300 supercharger, TSP LT headers, Pat G tuned, 667rwhp, 662rwtq, 191mph TX Mile.
2009.5 Pontiac G8 GT 6.0L, A6, AFR 230v2 heads. 506rwhp/442rwtq. 11.413 @ 121.29mph 1/4 mile, 168.7mph TX Mile
2000 Pewter Ram Air Trans Am M6 heads/cam 508 rwhp/445 rwtq SAE, 183.092 TX Mile
2018 Cadillac Escalade 6.2L A10 Pat G tuned.
LS1,LS2,LS3,LS7,LT1 Custom Camshaft Specialist For custom camshaft help press here.
Custom LSX tuning in person or via email press here.
Old 11-07-2005, 09:21 PM
gollum's Avatar
Patrick,
So my 14.1 AFR reading taken at tailpipe is actually about 13.1 AFR before my Random Tech. CATS.
Thanks, Keith
Old 11-07-2005, 09:27 PM
SideStep's Avatar
Well Pat, you have opened the bag of worms now...
Fortunately for me my WB sensor in way up front (header collector)...
Old 11-07-2005, 09:44 PM
Poik's Avatar
Originally Posted by gollum
Patrick,
Thanks, Keith
I think what he meant is that it could be different. Plus, I thought you weren't supposed to test at the tailpipe if you have cats on because they will make it inaccurate?
