View Poll Results: which one?
centerforce dual friction
27
50.00%
RAM HDX
27
50.00%
Voters: 54. You may not vote on this poll
centerforce dual friction or RAM HDX
I've never dealt with the ram, but I've been running the centerforce df for over 50k miles now. I've maybe burned out 4 times, and I've never had it at the track. I'm one of those guys that feels the need to downshift all the way down to first at stops. No noise, vibration, or chatter to speak of. The one peave I've had out of mine; Whenever I try to shift gears at high rpm, it gets a little notchy. I'm assuming the extra weights are pushing harder than my cylinder wants to hold. right now my car is at 349 ftlb & 327 hp at the wheel. Hope that helps you.
thus far (800mi.) i am VERY happy with the CenterforceDF...the thing grabs like a ****! no grinding, no slipping...the only isssue i have with it is going into gears sometimes feels a bit notchy...but other than that...beautiful piece of work! well worth the 390!
Where did you guys buy your Centerforce DF? Is this a good price?
http://www.performancecenter.com/pro...lications/5.7L
I believe this place does free shipping. Do you guys think this is a good daily driver clutch? Because my car is my DD.
Originally Posted by robster
i have a centerforce 2 in mine and i am having trouble getting it into gear. Shifting grinds. Acts like it not fully disengaged. what should i do
i have had my dual friction for about 20k miless...usually very good with it but occasionaly like to light it up...have about 430 to the wheels...it grips great but i have the same problem, it doesnt like to shift at high rpms...it also started making a chatter noise as if a little bit of it broke off...i will let you know when i change it out.
