View Poll Results: which one?
centerforce dual friction
27
50.00%
RAM HDX
27
50.00%
Voters: 54. You may not vote on this poll
centerforce dual friction or RAM HDX
Old 11-08-2005, 10:05 PM
RICEBURNER's Avatar
Question centerforce dual friction or RAM HDX
what do you guys think? any opinions welcome! buying one at the end of the week....
Old 11-09-2005, 10:19 PM
glennhl's Avatar
Why the dual friction? The best Centerforce clutch for the LS1 is their new DFX.
Old 11-09-2005, 11:11 PM
trackbird's Avatar
I installed one with a fidanza flywheel about 3,000 miles and a couple autocross events ago and I've been very happy with it. I'm not drag racing, but I am launching on 315 Hoosiers.
Old 11-10-2005, 12:22 AM
bodydropped's Avatar
I just pulled my centerforce df out.It stared slipping after 9 months.I just in stalled a ram powergrip hd and i love it.
Old 11-12-2005, 02:24 AM
RICEBURNER's Avatar
well...i went for the Centerforce DF...turned out that was all i could afford at the moment.....so we will se how it holds....*knock on wood*
Old 11-14-2005, 05:54 PM
richieg's Avatar
I've never dealt with the ram, but I've been running the centerforce df for over 50k miles now. I've maybe burned out 4 times, and I've never had it at the track. I'm one of those guys that feels the need to downshift all the way down to first at stops. No noise, vibration, or chatter to speak of. The one peave I've had out of mine; Whenever I try to shift gears at high rpm, it gets a little notchy. I'm assuming the extra weights are pushing harder than my cylinder wants to hold. right now my car is at 349 ftlb & 327 hp at the wheel. Hope that helps you.
Old 12-01-2005, 10:17 PM
RICEBURNER's Avatar
thus far (800mi.) i am VERY happy with the CenterforceDF...the thing grabs like a ****! no grinding, no slipping...the only isssue i have with it is going into gears sometimes feels a bit notchy...but other than that...beautiful piece of work! well worth the 390!
Old 12-05-2005, 03:32 AM
Mecinoid's Avatar
My DF has been in since '98. I haven't had single problem with over 60 12 sec runs.
It hits hard, no slip at all and just a tad heavier pedal feel than stock.
Old 12-08-2005, 05:23 PM
J&J Motorsports FL's Avatar
I just ordered the RAM HD so I hope it works good. I also had a LT1 stroker with a DF and it went through hell and still worked good.
Old 12-10-2005, 01:11 PM
1320Kid's Avatar
Centerforce.
I too and running it and it grabs like a son of a bitch, great streetability, and my buddies 650+rwhp T/A has been running it for God knows how long, daily driven.
Old 12-11-2006, 08:17 AM
robster's Avatar
i have a centerforce 2 in mine and i am having trouble getting it into gear. Shifting grinds. Acts like it not fully disengaged. what should i do
Old 12-12-2006, 02:37 AM
crazyed71's Avatar
are you guys using stock slave and masters?
Old 01-13-2007, 07:04 PM
scof0elife's Avatar
Where did you guys buy your Centerforce DF? Is this a good price?
http://www.performancecenter.com/pro...lications/5.7L
I believe this place does free shipping. Do you guys think this is a good daily driver clutch? Because my car is my DD.
Old 01-13-2007, 08:09 PM
scof0elife's Avatar
Also where are you guys getting the centerforce DF with the 12"? Need help guys, thanks!
Old 02-27-2007, 09:30 AM
00BlueTA's Avatar
I had a centerforce in mine and it worked great for abour 7-8 months and then started acting funny. It would not let me shif at high rpm pulls, but daly driving was fine. turned out the weaghts on the pp were sticking. I would go with the ram instead. But I went with the spec 3 after my centerforce.
Old 02-27-2007, 12:52 PM
TurboGibbs's Avatar
Can someone confirm the pedal firmness of the Ram HD? Is it similar to the CF? Stock? etc...
Old 02-28-2007, 12:52 AM
sidewayz28's Avatar
im in need of a new clutch and i think im leaning towards the Ram HD as well
Old 02-28-2007, 01:15 AM
sandro arellano's Avatar
i have had my dual friction for about 20k miless...usually very good with it but occasionaly like to light it up...have about 430 to the wheels...it grips great but i have the same problem, it doesnt like to shift at high rpms...it also started making a chatter noise as if a little bit of it broke off...i will let you know when i change it out.
Old 02-28-2007, 02:17 AM
Cole Train's Avatar
I ordered a Ram HDX for mine. Can't wait to get 'er in
Old 02-28-2007, 07:33 AM
corvet786c's Avatar
I just purchased the centerforce and installed it. So far I like it. Helps to shift quicker than stock, just a little stiffer than stock. clutch rated like 500hp.
Quick Reply: centerforce dual friction or RAM HDX
