Need Help with n20
Need Help with n20
i have a 98 mustang gt full built motor bored and high compression slp all the way, but i have a direct port setup jetted at 125 right know,, when i test it it works but it seems to cut out slightly and come back on,,, i dont have a bottle heater yet or a psi gage wiring is all good,,, seprate fuel pump delivers fuel and works fine NEED SOME HELP GUYS NOBODY ON THE MUSTANG SITES KNOWS SQUAT ABOUT N2O THANKS
If you have no idea what pressure your spraying at that's probrably the problem. You pressure is probrably to low and your getting some surging. It wouldn't be a bad idea to put a remote gauge on your standalone fuel set up either. That would be a good place to start.
First Thanks Yeah I Have A Gage On The Fuel System It Runs Around 70 To 80 Psi And I Also Have An Accumulator On The Fuel To But I Bet Ur Right Cause Sometimes It Goes Like A Bat Out Of Hell And Other Times It Dosent Again Thanks For Ur Help Im On Under My Friends Name
70-80psi when spraying? Where your jettings figured for that much fuel pressure? With a combination of that and a low bottle psi your probrably super rich making the car fall on it's face.
I Believe It Drops To About 40 And The Accumulator Keeps It Pretty Smooth Its The Jets That Nos Gave Me I Have 100 Hp And 125 Hp Jets Yes It Runs Slightly Rich I Have Had It Tuned But I Have Had Friends Tell Me That Some Times When I Fly By It Smokes And Other Times It Dosent I Have Pulled Out 10 Degrees To Be On The Safe Side For Right Know Ive Been Working On This For A Year Now The Whole System And Motor
