Time to change the clutch
Old 11-14-2005, 02:10 PM
prostock_bigblock's Avatar
Default Time to change the clutch
Hello everyone ,
Its time to do a culutch upgarde in my car , went to the track yesterday and the clutch burned at the second run.
anyways here is my plan;
1-spec stage 3
2-mcloed slave cylinder
3-GM 2001+ master cylinder.
I am thinking also to get a aluminium flywheel but I dont know if it is worth it over the steel one.
Ya another thing , I have saw on one of the sponsors web site a stage 3.5(sometimes stage3+) and there is no any discription on them.
any comments? advise will be apreciated
Thanks!
Old 11-14-2005, 10:20 PM
TheDogofWar's Avatar
you've got 2&3 mixed up.
2.Mcleod doesn't make an adjustable slave, it's the master.
3.The slave is the cylinder that needs upgraded and should be replaced with any clutch install.
The spec 3 pads are a carbon/ceramic combination using a 6 puck design, the 3+ are a full faced design using carbon metallic. The plus option is suppossed to give you more holding capacity than the spec4 while providing better manageability & wear characteristics than the stage 3.
Quick Reply: Time to change the clutch
