100/shot-125/shot dont feel no difference?
Old 11-15-2005, 01:58 PM
ls1birdman's Avatar
Default 100/shot-125/shot dont feel no difference?
ok when i ran a 100/shot it felt good but when i upgraded to a 125 it felt coo still but i couldnt notice the difference so should i go back down to the 100/shot or just stay there with the 125 and this is on stock timing and no fuel pump and all bolt-on and ram-air
Old 11-15-2005, 02:42 PM
Board Certified Idiot
Z2K_MrJ's Avatar
y not just Try 150 i am sure you feel that..And is it a wet kit or a DRY Kit you are SPRAYIng i think the wet kit would hit harder. puts more to the ground also
Old 11-15-2005, 04:01 PM
=ZoomZ='s Avatar
spray a 150 shot and make sure your bottle presure is up and you will see the GlOrY that is nitrous
Old 11-15-2005, 04:41 PM
jerrad's Avatar
why not go to the track and do back to back comparissons?
Old 11-15-2005, 05:31 PM
ls1birdman's Avatar
but would i been fine with my stock timing and stock fuel system until i can change it but i dont spray that often
Old 11-16-2005, 06:50 AM
Z2K_MrJ's Avatar
WET KIT you should not need to change ur timing for that shot.. just get a fuel pump..if you choose to spray 150 just to be SAFE.. Dry shot ull need injectors and prolly mess with ur timing and will need the PUMP also
Old 11-16-2005, 05:53 PM
Cheater's Avatar
Well thats the question dry or wet ????
Old 11-16-2005, 10:38 PM
ls1birdman's Avatar
Its a wet kit
Old 11-16-2005, 10:52 PM
setxws6's Avatar
Your a 99 and they had 26lb injectors and not 28lb like all other years...and that plus stock fuel pump, I think you may be running lean. Get a bigger pump and then fell the power of nitrous!
Old 11-16-2005, 11:14 PM
ls1birdman's Avatar
what type of fuel pump is good as far as the brand
Old 11-16-2005, 11:52 PM
setxws6's Avatar
Try Racetronix, it's what I've got, and it's complete plug and play. If not the Racetronix system then at least just a Walbro pump. Most of the sponsers have them.
Old 11-17-2005, 01:21 AM
ls1birdman's Avatar
ok thanks for the advice..
Old 11-17-2005, 08:46 AM
TNTramair's Avatar
easiest way to tell is to take it to the track and compare trap speeds between the 100 shot and 125 shot...you should see a good 2-4mph increase with the extra 25 shot depending on weather,mods, etc etc.
but like most have said...screw the 125 and go right to the 150shot...you'll never go back...
Old 11-17-2005, 11:10 AM
TINKRD's Avatar
like everyone else said, upgrade the pump and go to 150
i sprayed 100 3 times, bumped it to 150 and never looked back
night and day differnce.
Quick Reply: 100/shot-125/shot dont feel no difference?
