Freshen up motor??
Old 11-20-2005, 01:46 PM
CarrotcarZ's Avatar
Default Freshen up motor??
I'm in the market for a cam, but I have one question first. MY car's got 140k on the clock, so should I put in new bearings, rings, ARP bolts and what not.....or would it be fine the way it is?? TIA
Old 11-20-2005, 02:06 PM
SunroofZ's Avatar
They are some people on this board that have put cams in w/ pretty high miles. These motors only last as long as you take of them. These motors are strong ****'s
I am also pushing the miles. I am at 148,XXX miles.
It wouldnt be a bad idea. It would give you a piece of mind, especially if you want a big cam and want to spin the motor pretty high.
Good luck on the cam purchase.
Old 11-20-2005, 08:07 PM
CarrotcarZ's Avatar
I'm more than likely going with the MS3 from Texas-Speed......so maybe ill just put some new bearings in
Old 11-21-2005, 07:09 AM
King James's Avatar
Rod bolts would probably be a good idea being you'll be spinning pretty high with that cam.
Old 11-21-2005, 08:38 AM
HASTINGSRJ's Avatar
definatly rod bolts.....hell for $85.00 shipped from TX Speed you cant beat that...
Old 11-21-2005, 08:47 AM
PREDATOR-Z's Avatar
1- Do a compression and a leakdown test
2- Based on the results then make your decision.
Old 11-21-2005, 08:55 AM
GuitsBoy's Avatar
new lifters maybe too? Mine crapped out under 90 K miles
