New AFR 205/FM13 trying to dial in...idle issue
1 Post
Well new AFR 205 heads, FM13 114 cam, nextek springs, FAST intake all on...seems like we have a problem with the "Idle Adjust Motor" on the throttle body hanging up and not responding...i'm passing on this from my mechanic. Any comments...anyone with problems like this?
The motor is being set up for a dyno tune asap. We have enlarged the idle hole in stock TB to 3/16...stopping there until we get new "idle adjust motor". BTW I have a 2000, stock bottom, AT. Please feel free to wander off the question with any suggestions of preparing for the first few hundred miles witgh new heads, intake and cam.
1 Post
Originally Posted by DaddySS
So your mechanic changed heads, cam, intake etc. and thinks the idle motor went bad???
1 Post
Originally Posted by ninobrn99
u just need to get it tuned before anything. dont drill the TB anymore! flip the idle set screw up and adjust that to open the TB blade a bit. Very nice setup btw!
Nino
Nino
i also have the f13 and it sounds so damn good! well back to the idle set screw...im gonna assume u have a fbod. its under where the throttle cable connects. its a t15 screw. the head is under so you have to take it out and screw it down instead of up. does that make sense?
1 Post
Originally Posted by Macon
We will be looking...no biggie to take it out...have to trim the throttle cable guide too to facilitate full open anyway.
1 Post
Originally Posted by King James
Why? You can simply adjust the cable to make sure you opening the throttle 100% without trimming anything.
