Dry Nitrous and tuning>>
Old 11-21-2005, 01:33 PM
330racing's Avatar
Default Dry Nitrous and tuning>>
I am currently running a dry kit and am running on the lean side on the dyno. In order to remedy this I need to add fuel obviously, but that will hurt my N/A tune. Is there any way around this??
Old 11-21-2005, 01:50 PM
FirstYrLS1Z's Avatar
depending upon how big a shot you're running,your fuel pump(if stock)might not be able to supply enough fuel and keep the required fuel pressure at the fuel rails and/or your injectors have reached their limits in their ability to supply the proper amount of fuel per cycle.
Old 11-21-2005, 02:18 PM
Robert56's Avatar
Look for the thread dry tuning tip. it has info on using fuel adder vs IAT, a way to add fuel only on the spray. Search for threads started by Robert56. If that won't won't work for ya there are other options.
Robert
Old 11-21-2005, 03:44 PM
white2001s10's Avatar
One simple option may be to simply move your nozzle a little closer to the MAF.
Another option is to richen up the load sections of your VE table... the one you will hit while on the bottle only.
A third option is to use a CTS tricker to add coolant enrichment while the nitrous is activated.
There are other ways still.
Old 11-21-2005, 05:49 PM
highrevinhp's Avatar
what kind of dry kit?
Can you raise the pressure on the regulator by changing the jet maybe?
Or even get an adjustable fuel regulator.
Old 11-21-2005, 06:10 PM
aram's Avatar
Check to see if your fuel injectors are maxed out as well.
Old 11-21-2005, 06:27 PM
Robert56's Avatar
You can also use a resistor/pointometer to trick IAT, relay activated upon wot spraying.
Robert
Old 11-21-2005, 06:29 PM
Robert56's Avatar
Spiking fuel pressure, kinda like boost referenced, to trick injectors into being bigger is also an option. Like the dry LT1 kits.
Robert
