what rear gears to get
3.73 are all around a good set, and very good if FI. 4.10's are good for light to light. the higher the horsepower the lower the gear, as you may run out of gear when going down the strip. I would say get the 3.73's. higher the gears the worse the gas mileage.
i went 4.10's and love them on teh street but at the track with boltons and soem spray i run out of gear i was thinking to put 3.73 in my 9inch over the winter well see.... but if you drag race alot and plan on makin alot of power def. go 3.73.
If you go w a higher cam, hence high RPM range, you shouldn't run out of gear in 4th w/4.10's from what I understand. All depends on your internals and other mods!
I have had the same question proposed and was told that I would run out of gear w/stock internals. Heck, I am almost out of 4th gear now w/my 3.42's!
Excellent question, as I intend on installing CAM ONLY 228/230 and eventually will be changing over to a 9".
