Odometer can easly be changed
Ok, I am looking at 2000 Camaro SS with 20K miles on it for $13K. Too good to be true? Probably. But wait, there's more.
I am being told by the GM dealership that the computer has been swapped out. I am waiting to talk to the tech for confirmation to see if it has just been reprogrammed. In any event I did some digging around and found how easy it is to reprogram the digital odometer in ODBII cars.
So my question is, is there ever a legitimate reason to replace the computer on a Camaro and if so wouldn't that car get the milage that the car the computer was taken from had?
TIA
TIA
Ok, have you ever heard of a computer going bad on a OBDII Camaro?
The title report isn't much help either, it shows 12 miles in 2000 and then 9139 in 2005, then second owner brought it to ~20K.
I figured I am going to have to go based on wear if its actual miles. One thing I thought to check for is if it still has the OEM tires and if they look like they have 20K miles wear on them. Any thing else?
Would you buy it?
TIA
Would you buy it?
TIA
Changing the computer will not change the miles...the mile calculation is stored in the gauge cluster itself...you would have to swap out the gauge cluster or send it in to be recalibrated...
it is stored in the BCM and the Cluster, however, even with a tech 2, i was never able to figure out how to tell the milage in the bcm.
Both my cluster and BCM were replaced under warranty at different times, so I wanted to verify the milage, but have never figured out how to, any help is appreciated. I have access to a tech 2 and any cards needed.
Ryan
Ryan
Turns out when I talked to the Sales Manager the car was not for sale. He did not feel comfortable about selling it so he going to wholesale it at the dealers auction.
This experience has really opened my eyes to how easy it is to reprogram a digital odometer and how prevalent odometer fraud is. I found a few companies that sell professional equipment that talks through the standard ODBII port for several thousand grand, and then there's guys like these http://www.prospeedo.com that will do it for the unconscionable rip-off artist on a budget.
wrencher
Have replaced BCM's no milage change. It was my understanding that the cluster was the one that kept track of VSS pulses/milage.
When we needed to replace a cluster (dealer) they are sent out to a rebuilder. There are many all over the country. They have the equiptment to reprogram/rebuild clusters. Not a dealer shop.
this is 100% correct
Very few brands of cars hold the mileage into other moduals other than the cluster.
Camaros and most gm vehicles dont store the mileage in anything but the dash.
Hell, you can just pull the dash fuse and it stops the odometer..
Its up to you to really determine if mileage is correct on anything.
Those kits you speak up do require the dash to be taken apart, and, if you think it has been tampered with, the cluster will have the soldermarks on the back of the eprom board from where they had to connect wires to read and write the new information.
