Newbie questions
Newbie questions
Hey guys this is my first post and Im looking for some help. I am going to be buying a 98 or newer trans am with a 6 speed in the summer. But basically here is what I plan on doing. since I am on a budget I am going to either buy a high mileage car, or one with a blown motor. I would like to start building a motor for the car fairly soon. I am going to have a turbo, but I am not sure what yet any suggestions. I want to build a motor to handle boost, and be capable of high hp. 600+ to the wheels. I want something that will be streetable and wicked fast. I plan on building the motor my self. What would be the best combo for me. Thanks
7 Second Club
for the motor be prepared to spend atleast $6000... 6k is really cheap...
for the FI kit be prepared to spend atleast $7k.... for the fueling of this mean machine be prepared to spend $2500...
budget and FI dont go together.
with 600+rwhp you're going to need a good drivetrain- tranny,driveshaft, and rearend...
tranny= 1500+
driveshaft= 250+
12bolt or 9'= 2200+
as you can see $15,000 will go very fast.
I've had my car a little over a year and already dumped well over $14,000 in it... and havent even got to the new motor, fuel system and super charger yet
if you want a budget go N20.
just be prepared to spend some big bucks for FI.
tranny= 1500+
driveshaft= 250+
12bolt or 9'= 2200+
https://ls1tech.com/forums/newreply....ply&p=3858081#
tranny= 1500+
driveshaft= 250+
12bolt or 9'= 2200+
tranny= 1500+
driveshaft= 250+
12bolt or 9'= 2200+
We have an engine combo that works very well.
Callies Racemaster stroker crankshaft, making the engine a 382ci.
Callies Compstar connecting rods
Diamond forged pistons
Comp cam
Comp timing chain
Comp pushrods
New oil pump
ARP head studs
The stock crankshaft has been shown to be able to handle 900 to 1000 hp, so you could keep the stock crank, meaning the cubic inch would be kept at 346ci. With keeping the stock crank, we can pull your engine out, have all machine work and balancing done, rebuild it with parts listed above, reinstall your stock heads, or heads of your choice for an additional cost, reinstall the engine and tune it for $4,500.00. Bob
Comp cam
Comp timing chain
Comp pushrods
New oil pump
ARP head studs
That sounds pretty good. What compression is that motor. How long does something like that take for you guys to do. I don't have a car yet but I have a few that I am looking at. When I get the car it will not stay stock. I am hoping to have something built and running by next march or april. My buddy and I just finished building a vortec supercharged 468 for his nova and now it is time to for me to get something fast. Can I get some opinions on turbos and has anybody fabbed up a front mount single that has worked well. Thanks Chad
Comp cam
Comp timing chain
Comp pushrods
New oil pump
ARP head studs
Comp cam
Comp timing chain
Comp pushrods
New oil pump
ARP head studs
Originally Posted by RaRe99SS
Bob, what kind of power does this setup make? Where are you located?
