O2 sensors wierd, can somebody look at my log file?
Old 11-27-2005, 04:47 PM
Pavetim's Avatar
Default O2 sensors wierd, can somebody look at my log file?
I changed my exhaust system and put on 2 brand new rear O2 sensors from a vette. I got a code today for 1 and 2 bank O2 sensors not switching or something like that. And I notice when not in WOT the O2 sensor readings go from like 60mv to 900mv. Can anybody look at my hptuners log file and tell me how it looks. Thanks guys. Not sure how to attach a file so i'll email the file to you. Thanks.
Old 11-27-2005, 04:58 PM
SideStep's Avatar
I JUST did the exact same thing... send me your log file and I will compare it to mine... shamrockx@comcast"DOT"net just replace "DOT" with .
Old 11-27-2005, 06:41 PM
SideStep's Avatar
I got your logs and they look worse than mine actually, you are showing no switching (rich to lean) at all at idle... just flat lines.... You are getting these error codes because the exhaust gases are too cool (because of headers) by the time the gases reach the sensor. There are several here on the forum with the same problem.
Usually the answer is to do exactly what you did, replace the sensors with C5 rears. In my case it still is not enough. I guess I am wrapping the headers next in hopes of keeping the gases hot long enough...
Read this thread for more info...
https://ls1tech.com/forums/showthrea...ht=header+wrap
Old 11-27-2005, 07:51 PM
soundengineer's Avatar
usually a combo of coated headers and teh 2002 vette rear o2 sensors(bosch #13111) fixes that...but not always 100% guaranteed.....
Old 11-27-2005, 07:54 PM
SideStep's Avatar
Yupper... The LGs are the worst for this from what I have read here on the forum. I am wondering if wrapping them is really going to keep the temps up...
Old 11-27-2005, 08:03 PM
you can always pull them off and send them to jet hot for some coating...get their 2000 series and you wont have that problem anymore...I can drive for almost an hour and teh outside of teh longtubes are are cool to the touch on teh underside of the car....and the gas coming out the back is nice and hot
Old 11-27-2005, 08:39 PM
Pavetim's Avatar
I have the corvette rear O2's and have the coated pacesetters. What exactly is switching because the log I looked at the sensors go way up and down they are not flat?
Old 11-27-2005, 08:45 PM
Pavetim's Avatar
Hey sidestep think you were lookin at the inj log line. The O2 line on my graph is all over the place except for WOT which is pretty flat but think it supposed to be. Will it hurt the motor at all or screw the tune if the sensors are too cold?
Old 11-27-2005, 08:55 PM
it should look somethng like this
and WOT should be flat
Old 11-27-2005, 09:19 PM
WS6FirebirdTA00's Avatar
are you using bosch,denso or OEM vette rear o2s?
Old 11-27-2005, 09:25 PM
see above
Old 11-27-2005, 09:32 PM
i was wondering about pavetim, i have heard of problems with denso and bosch, i woudl just like to find more informaion on what everyone is using but the way it looks right now im going back to OEM vette rear o2s.
Old 11-27-2005, 11:36 PM
SideStep's Avatar
I have tried both, problem still occurs...
Old 11-27-2005, 11:59 PM
you had both of what? OEM included?
Old 11-28-2005, 07:38 AM
SideStep's Avatar
I have tried the OEM, Bosch, and Denso... Wrapping headers next...
Old 11-28-2005, 08:24 AM
i had best luck with oem, but i never tried oem vette rears
Old 11-28-2005, 05:11 PM
Pavetim's Avatar
My graph does look like the one you posted soundengineer. And I bought bosch rear 2002 vette sensors. Think they are like 13111 or something like that. Maybe i'll try wrapping them. Have to see. Oh and at WOT the lines are pretty flat. But if they seem to be working fine why would I get the codes.
Old 11-28-2005, 05:16 PM
what is teh exact code # you are getting??
Old 11-28-2005, 05:39 PM
SideStep's Avatar
If you are asking me, I am getting P0133 and P0153....
Old 11-28-2005, 05:57 PM
have you tried turning off proportional idle?? and lower the values in proportional fueling as well...sometimes its caused cause those values need to be adjusted cause now they are out of range
