500 miles on cam swap, chewed up cam gear and retainer plate??
I have roughly 500 miles on my cam swap, was having oil pressure problems so pulled things back apart. The back of the timing gear is pretty chewed up, and the cam retainer plate is all chewed up, where they have been rubbing together. The gear and retainer bolts were still tight There is a pretty deep groove worn in the retainer, and you can see where the bolt heads were starting to rub the cam sprocket a bit. All this rubbing made shavings that has chewed up the cam bearings. The cam still looks new, but I am going to send it back to thunder just to make sure I havn't messed it up too. I popped the rod caps off, and the rod bearings still look good, but have some scores from the shavings too. Anyone have any Idea what I have done wrong for this to have happened?
I have read that, and will use the tips on the rebuild, but still wondering why this happened this time, when I put the cam in, there were no signs of wear at all, now there is a deep groove in the retainer & gear.
Since the cam swap, it has not really had "great" oil pressure. The motor only had 15,000 miles so I didn't mess with porting the pump, but I did shim it. I didn't have the pickup apart, so I knew it wasn't a pinched or torn oring. I drove it a hundred or so miles, pretty easy. Made 7 pulls on the dyno, In the following days the oil pressure kept dropping off when warm until I would only have about 25psi when reving a bit. It wasn't knocking or sounding abnormal. I cut the oil filter apart and noticed more than normal metal so I tore it down. None of the bearings look bad from wear, just scraped up from the shavings. It is possible I put the cam bolts in the retainer, or vice versa, but they look the same to me, and everything was still good and tight. What supplies oil to this area?? Thanks for the replies.
I did not change the timing set, just reused the stocker, the motor had really low mileage, and I wasn't planning to put more than 7,000 miles a year or so on the car so I felt it wasn't necessary. I agree with the thrust load, just not for sure why, everything went back together smoothly, and it wasn't making a lot of racket to indicate a problem. I am going to try to borrow a camera to better show what I am talking about. It seemed dryer than I thought it would have inside the timing cover, maybe it isn't properly getting oiled?
I tried taking a couple of pictures, but the camera just wont show it clear enough to see what is going on, I tore it completely down today, and you can also see where the back of the cam has rubbed the rear cover plate? Any insight is appreciated.
Did you remember hearing any noise coming from the timing set area while it was running? You would think if it was rubbing like that it would have been audible.
