Hard to get into first gear.
Old 12-03-2005, 06:45 PM
Spenser309's Avatar
Default Hard to get into first gear.
The past 2 days my car has been very diffiult to get into first gear, and grinds if i try to shift gears faster than normal. What's wrong with it?
Old 12-03-2005, 07:02 PM
DAVESS02's Avatar
Sounds to me like you have a slave going out or air in the system. Check the fluid level and check back in.
Old 12-04-2005, 01:12 AM
white mongoose's Avatar
i have the same problem and people been telling me that i should do the drill mod and change my clutch fluid
Old 12-04-2005, 04:34 PM
Spenser309's Avatar
yea, my clutch fluid looks like burned oil and i guess its low, didnt see any lines on the resivour though.
Old 12-05-2005, 10:58 AM
Spenser309's Avatar
ttt. i really dont know what to do, this is my first m/t car.
Old 12-05-2005, 09:17 PM
DAVESS02's Avatar
Do you have someone to help you bleed the system? If so, just make shure you keep plenty of fluid in the reservior-check it every two bleeds. See how it does and repost. Also, you can check the rod where it comes into the car on the clutch master cyl. Check to see if your low fluid is caused by it leaking at the back of the clutch mastercyl.
Old 12-07-2005, 03:34 PM
Spenser309's Avatar
uhh dont really have anyone to help. Neither my dad nor i have had a M/t car and i dont know anyone nearby, plus its snowing. lol.
Is there any write up anywhere on how to do this?
Old 12-07-2005, 07:38 PM
zdawg28's Avatar
ttt for ya, having the same problem, but my car is already at the shop ill let you know what they come up with.
Old 12-07-2005, 07:42 PM
blu02ss's Avatar
It may need a new clutch assembly.
Old 12-08-2005, 05:09 AM
EPP
EPP's Avatar
Try putting it into reverse before you go for 1st gear, that should help until you can check out the hydraulics. Bob
