Odd O2 behavior after leaded 110 octane
Old 12-04-2005, 08:49 PM
dhdenney's Avatar
Default Odd O2 behavior after leaded 110 octane
I'll try to keep this short. Went to the track, put 5 gallons of race gas in, I broke ****, packed up and came home. Took it out the first time the other day and it drove fine but I was in open loop. I had unplugged the O2's to get it to the exhaust shop to have my exhaust modified due to clearence issues with the new BMR TA relocation. After plugging the O2's back up, driving home it started driving like ****. I let it cool down and started it up but did not drive it. It seemed ok but I imagine cuz it was in open loop. Poured in 5 gallons of 93 and fired it up tonight to drive with the PCM communicator and while in open loop, it drove ok--O2 voltages seemed normal. After getting in closed loop again, O2's looked good with my foot on the gas but 0 throttle brought them down low, in the 200's and 300's mv range. At one point, I tried some semi hard acceleration (half throttle) and it was like I hit a wall (no fuel) and O2's dropped to about 13 MV. I am semi-confident this is related to my race gas. Will my O2's improve or are they on their way out?
Old 12-04-2005, 09:08 PM
WS6FirebirdTA00's Avatar
was the 110 leaded?
Old 12-04-2005, 09:11 PM
dhdenney's Avatar
Yes, leaded 110.
Old 12-04-2005, 09:12 PM
SUTTERERMAN85's Avatar
the lead will f up your O2's
Old 12-04-2005, 09:17 PM
dhdenney's Avatar
But my question is will they improve and be ok or does it sound like they're shot?
yep thats your problem, o2s are shot. get new ones and DO NOT run leaded racing gas
Old 12-04-2005, 09:19 PM
ok you need new ones. i'd run unleaded next time too. just kidding.
Old 12-04-2005, 09:22 PM
dhdenney's Avatar
Well I seriously didn't think they would go that fast. That was the first time I ever used it. Theoretically, in PE O2 input is ignored right? If I ran open loop and was satisfied with drivability and my PE was tuned to 13:1 (which it is), I can get away with open loop then right?
Old 12-04-2005, 09:48 PM
black01_WS6's Avatar
do not use leaded race gas, get some torco. you o2's are on their way out.
if the entire ve table is properly tuned
Old 12-04-2005, 09:56 PM
horist's Avatar
your O2s are likely FUBARed .... doesn't take much lead to coat them and make them lazy/incorrect....
however , if you plan on running leaded gas often... as you surmised ... you can do an open loop tune to not use the O2s at all (only thing that sux is you won't have any reference as to where your AFR is ... lead will kill wideband O2s just as quickly)
Old 12-04-2005, 10:00 PM
dhdenney's Avatar
I did some SD tuning with VE Master this summer. The entire table has been scaled by VE master.
Old 12-05-2005, 11:29 PM
Bombguy99z28's Avatar
I drove around a few times with my o2s shot. Won't really hurt anything, the car will just run really really messed up when it wants to be in closed loop. I stalled it about 50% of the time I had to let it idle at a stop light
Old 12-06-2005, 09:22 PM
dhdenney's Avatar
I'll try open loop for a while. I think it'll be fine. I just don't wanna spend the $100 to fix them.
Old 12-06-2005, 09:48 PM
NO CATZZ's Avatar
From your post it sounds like you drove around with the O2's unplugged for a while...is that true? If so and you did not completely remove them that will screw them up as well. They will not heat up enough to burn off contaminates and become completely useless...add that to the fact that you were running leaded race gas and you get a dead O2.
BTW I have 3 O2 sensors(used) laying around that I will sell you for cheap. PM me if interested.
Old 12-06-2005, 10:50 PM
yeha i also have an o2 for sale
Old 12-06-2005, 11:13 PM
Leaded gas will kill o2s no matter what, plugged, unplugged. Killed mine in about 15 minutes... I watched their death thralls with hptuners, it was hot.
Old 12-07-2005, 03:17 AM
dhdenney's Avatar
No it wasn't a while. It was like 10 miles. Just long enough to get to the exhaust shop. I guess it was hopeless either way.
