Look good to you guys?
Old 12-09-2005, 06:04 PM
SSU's Drunk Typing Whore
Lithium's Avatar
Default Look good to you guys?
Everything look good (dot to dot) ?
Installed the MS3 and the rollmaster double roller.
Old 12-09-2005, 06:14 PM
NX_CaGEdApE00's Avatar
perfect
Old 12-09-2005, 06:21 PM
Orange Peel's Avatar
Looks good, but I think you forgot something..... oil pump??? Might not work so well without that haha j/k
Old 12-09-2005, 06:22 PM
Lithium's Avatar
Hahaha yeah might run into a couple problems.
Old 12-09-2005, 06:35 PM
iamsickofitall's Avatar
well at least the dots are lined up
Old 12-09-2005, 08:04 PM
Lithium's Avatar
Quick question:
I am putting in the LS6 oil pump now.
Do you have to put the o ring inside the oil pump when installing it? or can you just put it on the first ring of the pick up tube?
Old 12-09-2005, 08:43 PM
put it over the pickup tube then slide the oil pump over it - be careful not to pinch the o ring on the edge of the pump when sliding the pump over the tube
Old 12-09-2005, 08:45 PM
Lithium's Avatar
Alright cool, thought that way would be a little easier.
Thanks.
