View Poll Results: What springs are you running and is your valve train noisy
Comp 918
47.62%
Comp 921
14.29%
PRC Platinums
9.52%
PRC Golds
0
0%
Patriot Golds
19.05%
Crane 832
9.52%
Comp 978/987
0
0%
Revs
0
0%
Voters: 21. You may not vote on this poll
People with noisy valvetrains
Old 12-10-2005, 10:42 AM
HumpinSS's Avatar
Default People with noisy valvetrains
I am running the PRC Platinums with a G5X4 and my vt is just as quiet as the stock setup. Stock rockers with 7.4" PR
Old 12-10-2005, 11:12 AM
PREDATOR-Z's Avatar
What size p-rods are you using? and what kind of rockers?
Old 12-10-2005, 11:15 AM
HumpinSS's Avatar
is your setup noisy or not?
Old 12-10-2005, 01:06 PM
PREDATOR-Z's Avatar
Was and I was able to reduce it with 7.425 p-rods.
PRC platinum, XE-R cam, (was 7.40), GM .054 graphite, heads milled .010
Old 12-10-2005, 01:27 PM
Crazy Man's Avatar
patriot golds and it sounds like a bad *** sewing machine lol
Old 12-10-2005, 01:50 PM
TAQuickness's Avatar
my top end is currently under construction. the previous set up used oem lifter's, jesel SS's, & isky springs on a 238/242 xer lobe.... you could barely hear it over open headers
new set up should purr like a kitten
Old 12-10-2005, 02:56 PM
Dan_the_C5_Man's Avatar
918's - LPE GT2-3 - 7.425 PR's, very slight sewing machine noise between 2-3,000 RPM.
Old 12-10-2005, 03:07 PM
white2001s10's Avatar
Nothing to do with this thread, sorry, but have you had your car dyno'd? and does your engine feel lazy up to around 4000 RPM?
Just curious and want to compare to a similar combo.
Thanks
Old 12-10-2005, 06:40 PM
Jimbo'sZO6's Avatar
Crane 832 duals, Comp hard rods 7.350" Comp 232-236/.595-.605 cam on a 114+4 lobe and yes its noisy, but music to my ears!
Old 12-10-2005, 07:28 PM
ЯєŧąяĐ Єl¡m¡иąŧøя ™
orangeapeel's Avatar
918's with 244/248, 7.350's Comp PR's. Sew away!
Old 12-10-2005, 10:45 PM
Restricted User
CAT3's Avatar
Cant vote on this, on the same cam, and pushrods, I had run 918's and PP Golds. Still loud vt. Hopefully my engine swap will be done tomorrow and will find out whats up with the springs ET Performance uses on their new castings. I'd love a quiet vt though. Might experiment with prod length if I have the same noise.
Old 12-11-2005, 12:45 AM
racecar's Avatar
I thought that my Comp R lifters were the source of noise in my motor. I have enlarged the holes in the head for pushrod clearance. Turns out that the pushrods were hitting down inside the head.
