Pics of my heads!! opinions wanted!
Pics of my stage 3+ heads!! opinions wanted!
what do you guys think??? i noticed that the material removed has actually gone so far that it ran into the rocker bolt's tapped hole... is that a bad thing?? these heads are used and were just cleaned up with a 5 degree valve job...
dyno numbers from original owner :
440 RWHP naturally aspirated
and 650 RWHP and 680 RWTQ on a 200 shot
he was running a stock bottom end heads and cam LS1. so obviously these heads perform !! they are now being installed on my 408! woot woot!! im freaking excited!
oh yeah BTW.. these are patriot stage 3 LS6 heads, with additional porting done by speed demon??? i think that was the company that did the additional porting?? ill hafta make sure!
It's normal to break into the rocker bolt holes when porting these heads. Just use some 565 loctite to seal the bolt up so you don't pull oil into the intake runner.
how does the port job look?? does it look pretty good?? lol i have no idea what too look for... all i know is these heads put down wicked power on the previous owners car.
also... the heads have been milled twice now... how in the world do i figure out what my CC size is??
You can do it yourself by getting a small piece of plexiglass and a large syringe like one sold in a farm supply store. Cut the plexiglass big enough to cover the chamber, drill a small in the plexiglass and apply a small amount of grease to seal the plexiglass to the head. Then simply fill the syringe with water and keep up with the cc's that it takes to fill up the chambers.
awesome, thanks for the idea gunnar!
Loctite hasent held up for me and was advised to use a liquid teflon. That did the trick. Seems the loctite gets brittle, cracks and eventually works itself out. I know that when I checked all the loctite had disintegreated.
Mark
Mark
Mark
Mark
well.. i checked the CC size last night... they are coming in at just under 64 CC's... i think they were originally 68CC's and then after being milled twice it brought em down to just under 64
