ASP Pulley
ASP Pulley
http://www.lmperformance.com/599/
Does this deal come with a new belt? If not, where can I get one. I need the the crank belt, and A/C belt.
I can just get another crank bolt from a dealership, correct?
Since you have an Auto you'll need alt pully too...check out page for more info
http://www.ws6project.com/user_stor/...d71c468125af1a
Yes, the bolt can be purchased from a local dealership. I used Good-Year Gatorback belts #4040377 for the AC & #4060760 for the crank, alternator, PS pump. My alternator pulley is 2-1/4" diameter. Don't know if the stock diameter is the same. Would check the alternator diameter prior to belt purchase.
"Since you have an Auto you'll need alt pully too"
i have an ASP underdrive pulley set also ... crank and alternator pulleys ... for my 99 z28 w/ 6 speed.
are you saying that i don't need the alternator pulley since i've got the manual trans ??? i don't recall reading that anywhere in the instructions.
