Latest Incon Dyno - 644/701
Well, I still have a smoking turbo problem, but figured I would finish dyno tuning it anyway. I'm pretty sure I've maxed out these little turbos, unless someone else can some up with an explanation.
The extra cubes of this motor over stock displacement is eating the capacity of these turbos I think. Saw it spike to 15psi on race gas, but settled within a couple of seconds to 12. That and really didn't see a lot of increase in hp beyond 12.
Here's the dyno sheet:
#26 is after the first couple of attempts to straighten out the AF. This was at 11psi. #29 is final #'s on pump gas ( still 11psi ), I'm not thrilled about the peak #'s but we all know that's a small part of the equation. Nic doesn't really feel safe about running more than that on the street on shitty 91. I think we could push it further . . .
At 2500rpm I'm 60ft/lbs of torque more than the last nite of my stock motor. I hold on to it longer at the end also, so all in all I'm quite happy. #33 is the #'s on on a 50/50 mix ( doh, too much 91 in the tank, oh well ) of 91 and 101. That's the reason we didn't go crazy with too much timing, probably only had around 96 octane. At least I cracked 700 in torque!
Now . . . believe it or not, I'm still running the stock LS1 intake . . . and the TEA heads are unported . . . they were just cleaned up with larger exhaust valves put in ( I was on a budget ). How much could the heads/intake be holding me back? I'm also running a 222/218 563/561 114lsa cam . . . could it be hurting me any?
- Dug
- Dug
Coal Mining Director
I think that's a great curve! Plenty of power for low tens. Depending on your weight 9's.
How are you controlling the boost?
Did you try to over boost it to 17psi for a pull?
Exhaust set-up?
Good job!
Exhaust set-up?
Good job!
onfire, thanks! I've got the Greddy Profec-B controlling it. Did not try to overboost it, didn't have a great mix of gas, I'd estimate 96. Exhaust is 3" all the way to the rear, no cats, bullet mufflers dumping in front of the rear axle.
That's what I'm wondering cablebandit. I have the 35's, didn't you have the 37's? And how much did you get on those? How much do you think I might realistically gain from the ls6 intake alone? BTW, on 91 octane, what kind of timing curve would you guys run with how much boost on my setup? I think the timing could be higher than it is on pump gas even, I think I'm sitting as low as like 16 and as high as 20 . . .
- Dug
- Dug
i have the smallest incons...whatever they are. My last dyno was sae 736/750ish at 15.5psi on my autometer boost gauge. On my eboost2, that same boost shows as 16.6psi
My dynos are always on 93/meth and timing is around 15 degrees ramping to 18. my other cam dynod 703/775 at around 15psi
cablebandit, did you hold boost all the way? What was your CR? onfire, I'm not sure . . . how would I find out, would it be stamped on the housing?
- Dug
- Dug
Interesting . . . why do you think my boost is dropping off then while yours holds boost? I'm also around 8.7:1. Something's not right . . .
- Dug
- Dug
mine are some old GTp ported heads......stock valves
The ls1/ls6 intake swap netted me a noticeable butt dyno increase. I dunno how much but once you get over 500hp...an increase that you can FEEL has to be a good amount. ESR noticed the same increase up top when he switched.
8:75-1 346
gtp #317 heads
ls6 intake
215/215....550ish cam 114lsa
double valve springs
stock maf
tr6 35 gap
ported tb
stock intercoolers
I wonder if the ls1 intake could be holding you up that much. harlan switched i think while running the Incons so maybe he will chime in.
remember harlan made 600 mustang dyno on a stock motor at 10psi with racegas....so i dont think the heads are your problem
8:75-1 346
gtp #317 heads
ls6 intake
stock maf
tr6 35 gap
ported tb
stock intercoolers
yea, what octane was he running? I heard he ramped the timing all the way up to 30 on that gas . . . and my cam should be fine then, it's a 222/218 561/563 114lsa . . .
Your boost isn't holding due to the boost controller settings (my guess). Play around with the controller and get a settled boost around 16-17psi and th hp will come (with a proper tune)...a small spike is normal...my eboost2 jumps to 13.5 then settles down quickly to 12. You probably want the wastegate springs around 10psi.
- Dug
- Dug
Originally Posted by peter@aps
Dug, What type of exhaust are you running? You may have very high exhaust back pressure which can also limit the potential boost pressure.
ok . . . did some examination of my video ( took video of the gauges ) frame by frame.
One thing I've noticed about the last two race gas runs is that they both spike to 15, settle down to 12 . . . now the interesting part. My pump gas dyno was for 11psi. In that run it hits peak boost at EXACTLY 3500rpm. Guess what rpm it hits 12psi in both race gas runs?
3500 RPM
To me, that's telling me that the 15psi is indeed a spike ( explaining why it doesn't hit that until 4000rpm ), and which is why it settles back down to 12psi.
One other possible explanation is my boost controller. A couple of years ago I was having bad boost spike issues . . . so I turned the balance **** on the profec-b all the way to sharp, which is what the manual tells you to do. That always helped but didn't alleviate. Then I checked out the dip switches in the back and it was configured incorrectly. Fixed that and voila my spike issues were pretty well gone. BUT I never revisited the balance ****. Now I either have a boost spike ( which shouldn't be possible according to the controller settings on sharp ) OR I have boost falling off, in which case you need to turn the balance know towards mild. So it could either be a boost spike or it's boost falling off.
What do you think? At any rate all I have to do is do a bit of testing to figure out what it is, just gotta get the race gas tune in and do it.
- Dug
3500 RPM
- Dug
