MOSAR 12-BOLT installation... eazy or hard? opinions?
im thinkin about installing a mosar 12bolt after my rear goes up....anyone intall one? easy? hard? also how are they? what gears u recommend? options? is it worth it? anyone!!!!
This install is not difficult at all. The Moser 12 bolt is a quality piece. I purchased mine a year ago from Exotic Performance with all upgrades. Gear ratio will depend on your future mod plans. If you are going cam only and moving up your rev limiter go with 4.33s. If you are only planning heads and cam go with 4.33s or 4.11s. If you are planning cam and spray go with 3.73s or 3.90s.
Originally Posted by Exotic Performance Plus
Give me a call when you are ready to purchase one. Moser has the rear ready to ship to you two days after the order is taken! Bob
I thought you buy all the parts and build them yourself in house.
moser 12 bolt
last summer i installed a 12 bolt moser i got from SLP with 3:73 gears i also got the install kit this made it a lot easier but beware if you are going to keep your abs system (only if your rear has the relucter ring on the end of axle the coge gear looking piece) the brake backing plate needs to be machined down for clerance prepose. i would also grind a wrench to get to the bolt if the face plate of the axle dosn`t have a hole for a socket.good luck
