threw SES does this work??
hey whats up, I just moved down here. I have done that before and it has worked, but just take it to autozone or something and they will check it for free, and can clear codes. at least then you know what the code is for.
ever go cruzing at the beach.
i dont go cruising too much....but every once in awhile, i know the code is for my 02's because i i had to run my car with no front or rear 02's just a couple miles homeafter my header install, but anyways i finally got the extensions and simulators today so i put them on but its still shootin the SES and runnin like crap they sound amazing though!!!
If you have everything set up, like the extensions and sims, then you schould be fine when you get the code removed. It will keep reading the code until you remove it, but you probably already knew that. try taking the negative off the the battery for 15 min or so then put it back on and fire her up. works for some people.
