wat are some good aftermarket axles?
Old 12-31-2005, 06:07 PM
MiaSSmaro98's Avatar
Default wat are some good aftermarket axles?
hey i have a 98 ss ,and i have a vibration problem and if incase it is a bent axle ,i will like to get a nice decent set.so some opions are wat are some good companys in axles and that are not to expensive will be nice
Old 12-31-2005, 07:21 PM
1999Z28's Avatar
unless it's a really bad vibration i doubt it's a bent axle. I'd just replace it with some factory ones, the axles don't break near as often as the spyder gears do...the 10 bolt isn't worth the money...otherwise i'm sure Moser makes some good ones.
Old 01-01-2006, 12:21 AM
bolton98TA's Avatar
what would be a good way to tell if an axle is bent or not?
Old 01-01-2006, 01:58 PM
J&J Speed Shop's Avatar
Moser C clip axles are very strong and priced right
Old 01-01-2006, 05:18 PM
what are there price?and that is a good question,what is a way to know if u have a bent axle?
Old 01-01-2006, 08:45 PM
Mike2000Z28's Avatar
I have been in a hunt for a vibration that comes on when I hit 70mph, but smooth as silk until then. Here is the list of parts:
Moser axles = $230
bearings = $60
Ring and pinion install kit = $120
Aluminum DS = $330
two sets of ujoints for stock DS = $40
tires balanced twice = $20
not much better then before changed everything, the pinion angle is fine. A bent axle would show it self at low speeds and the bearings would give a grinding sound over time. I have tried pretty much everything to fix the problem, nothing works, I have very few people to bother/talk to about this problem. I'm going to spend my cam and head money on pulling the tranny out and rebuild it and work from there back to the rearend to see what is bent or causing the bad vibes.
Sorry to vent on your post but I just started replacing parts and thinking I spend alot of little money on nothing.
Old 01-03-2006, 06:51 PM
damn thats alot of money spent.are ur rims bent?
Old 01-03-2006, 09:26 PM
They seem straight dude, the machine used to balance the tires would have told me if the rims are bad, but I still think it might be.
