Stage 2 4.8/5.3 Cylinder Heads & Other Parts
We have 4 sets of our stage 2 4.8/5.3 Cylinder Heads milled to 62cc chambers. These are NEW GM castings, not core heads. These come fully CNC'd ports and chambers. Installed are Bronze valve guides with interlocking valve seats with our CNC valve job. Parts that are installed are REV 2.055/1.570 Super Duty Valves and Patriot GOLD Valve Spring kit.
Sale price on these 4 sets is $1350.00.
If you would like a Comp Cams camshaft $350.00
If you would like a FAST Intake Manifold
90mm 54003 $ 769.95
78mm 54001 $ 699.95
90mm 54003 $ 769.95
78mm 54001 $ 699.95
I've been looking into a set of your 225cc castings but these look like a killer deal. I'm going to PM you a few questions if you don't mind. Thanks,
Larry
Larry
Craig,
have you got a set of 265cc for 4.000 bore at stock or do we have to wait like the other for 2 months. and if i needed a 45cc chamber will that requir a sheet metal intake or the Fast one will work just fine
thanks
thanks
