2 step?
Matt, I've got 1 of your old ones, how is the new 1 different?
Originally Posted by y2khawk
I'm still targeting late Feb for them. I should have the bits for the first prototype piece in a week or so
Originally Posted by algws6
Matt is it going to be a direct plug in for the vettes or are we still going to have to use a relay on the clutch wire?
The inputs for arming/latch/etc are now configurable. You can choose to have them active with ground or 12V applied, and also which way the switch is setup, normally open/closed.
The base unit will be pretty much the same otherwise. The harness is now removable, with a sealed connector at the enclosure.
also changing the "relay output" to an actual onboard relay with all 3 terminals available for use. That way the user can choose how to use the feature.
from there, the upgrades (released after the base unit) will include a 3 step version providing a second adjustable limiter for staging, burnout, etc. With a variety of options on how the 2 limiters interact.
There will "hopefully" be an option to add an adjustable retard feature when the 2 step is active. I'm leaving myself open to add that feature as I'll be trying to get big turbos to spool. If it works like I want/think it will be an option for upgrade.
I am also leaving myself open to add a remote control feature. But that's low on the priority scale.
so basiclly u have to get someone to let go of their precious harlan 2 step which is like pulling teeth. i tried to find some sort of info on these but its almost impossible to get as well. like how they work and what they will do and how they are installed/ opertated etc. i hate making a blind purchase but i know i will anyways.
harlan, if you need a prototype, how long would you need it for?
Ive got one coming and my cars not back yet, so maybe i can help you work something out.
shoot me a pm if itll help you out.
