Wife's car got broken into!!!!!
Old 01-09-2006, 12:37 AM
ЯєŧąяĐ Єl¡m¡иąŧøя ™
orangeapeel's Avatar
Default Wife's car got broken into!!!!!
Well, my wife's **** got broken into and the moron ******* didnt take anything but the shitty head unit. I wouldnt be pissed if it was the only thing that had happened.
Well, goodbye driver's side window. It appears that the brick was no match for the glass. (only good thing that came out of it is that the glass stuck to the tint.) That is the ONLY good thing.
However, has anyone ever had their "automatic transmission" car broken into?
The reason I ask is because the thief yanked the shifter back out of park into nuetral. And now I think the linkage is FUBAR'd. well I finally got it in drive, but what the hell do I do about it? Can I just take the shifter off and then put it in the appropriate position or whats the deal? It is basically stuck there. I had to disconnect the battery because the key was still stuck in the ignition.
<--------------- own's an M6 has not alot of experience with the shifter on an auto.
HELP ME!
Old 01-09-2006, 12:59 AM
SSilverSSurfer's Avatar
same thing happened to me minus the shifter deal...sorry to hear aobut it
Old 01-09-2006, 01:16 AM
ЯєŧąяĐ Єl¡m¡иąŧøя ™
Yeah I just want to know if i need to replace the shifter/pull the transmission....I hope not. It is a 1999 Sunfire 2.2 lt. so front wheel drive.
Old 01-09-2006, 02:13 PM
1gen's Avatar
you should just be able to install a new linkage cable. I used to have an auto 92 camaro that the linkage broke in reverse in a wendys drive through with 10 people behind me. I just pulled it back and then pulled the ebrake got under it and shifted it by hand into drive drove home then pulled the cable and reinstalled and all was good. Also you might wanna take the top apart and check the fittings on the inside as one time my moms fell of on her 4 runner and I just pulled the top apart and zip tied the fitting back on and it was good to go again
Old 01-09-2006, 07:38 PM
ЯєŧąяĐ Єl¡m¡иąŧøя ™
Awesome. I just don't know what to do.
Old 01-09-2006, 08:33 PM
V6 Bird's Avatar
tehy broke the cable housing itself....just get under the car and slide the cable off to put it in park manually by the lever then pull on the cable itself while shes in the car with her foot on the brake and it should put the shifter back in park when you pull on it...Then you can get the key out.
Old 01-09-2006, 09:26 PM
mitchntx's Avatar
If this is an F-Body, I have a driver's side glass, in good shape, I'll give you, if you want it.
I have stripped a Z28 to make into a race car and have no need for the glass.
I'm Sw of Ft. Worth in Granbury ...
Old 01-10-2006, 12:23 AM
ЯєŧąяĐ Єl¡m¡иąŧøя ™
I wish it was an f-body. pontiac sunfire.
Old 01-10-2006, 12:24 AM
ЯєŧąяĐ Єl¡m¡иąŧøя ™
but what would I need to replace? it is front wheel drive. would that make a difference?
Old 01-10-2006, 12:39 AM
Donohue96M6Z28's Avatar
damn thats gay man..
a few years back someone broke into my friends car and my car in the same night , just broke the windows and didnt take anything, i was like wtf..
what sucked even more was he came by my house in the morning and picked me up (i didnt go to my car at all)and i was talking **** about his car being broken into and when i came in in the afternoon i saw that my car was broken into also, it was gay
sure does ruin your day, hope everything gets worked out
Old 01-10-2006, 01:25 AM
ЯєŧąяĐ Єl¡m¡иąŧøя ™
thanks for the kind words guys. I really am pissed off!
Old 01-10-2006, 01:33 AM
s.o.m.SS's Avatar
yeah my buddy had an 02 tahoe and for some reason when you put GM's into park it allows the dash pieces to be taken off... something like that
Old 01-10-2006, 07:41 AM
V6 Bird's Avatar
replace the shfit linkage cable most likely.
