What are you using in your alky kits?
I am running a devilsown progressive kit. http://www.devilsownonline.com/alcoh...products_id=12
Its cheaper and i belive its one of the best kits. I had a snow and switched to this.
Not bad bang for the buck, but I prefer a higher psi pump. 100+ minimum, most the good ones are 140-150 psi which gives much better atomization than this units 60 psi.
Jody
Jody
Jody
See I already had an alky kit. I just was not sure if i should switch. I am glade i did. I can tell you 1 thing. Somethign the owner told me. The 100 and 150 psi pumps the other companys are selling are acutally 60psi pumps with the pressure switch modded. Something about the motor size was the same size as his and sureflow only makes that pump in 60psi. So he things the other companys are doing some switcher ro. I just asked him all about this because I had 2 pumps that looked identical to me one from him and one from my orginal alky kit.
