Which head to use with my cam?
Old 01-11-2006, 08:26 PM
vodas00ss's Avatar
Default Which head to use with my cam?
Im thinking of getting a set of heads to intsall when I do my cam swap. The cam I have is a custom grind between the F13 and F14 it is a 230/234 .595/.598
Which set of heads do you guys recomend I compliment this size cam with, also what thickness of gasket to use?
Old 01-11-2006, 08:32 PM
SMDLS1's Avatar
What is your budget, when I had the cam I had some Meaux's Racing/Futral 5.3 heads to go with it.
Old 01-11-2006, 10:00 PM
vodas00ss's Avatar
ttt...?
Old 01-11-2006, 11:57 PM
BriancWS6's Avatar
If you have the dough you can't go wrong with a set of AFR 205s IMHO.
Old 01-12-2006, 05:45 AM
PREDATOR-Z's Avatar
I run a similar cam (Torquer V2) and i'm using PRC 2.5R/ 5.3 L with great success. check sig.
Old 01-12-2006, 09:26 AM
Gunnar@Patriot's Avatar
We have had several customers who have used the f13 with our LS6 style stage II heads and have liked the set up. Right now we have our LS6 style heads and also some 243 CNC ported castings that are availabe at a great price. Either will do well with your cam.
Old 01-12-2006, 10:49 AM
!LS1 11 Second Club
SouthFL.02.SS's Avatar
ETP 215's or 225's.
Old 01-12-2006, 11:00 AM
ЯєŧąяĐ Єl¡m¡иąŧøя ™
orangeapeel's Avatar
Budget: Patriot is your best bet. Plus I am partial to some company that will pipe up in the thread. Seems like Gunnar back their stuff really well!
Old 01-12-2006, 11:13 AM
99blancoSS's Avatar
Depends on your budget. The ETP's seem to be producing some serious numbers right now but they're also some serious coin. the 5.3 heads out there raise compression and produce very nice results for a lot less money. I'm running TSP/PRC 2.5's, numbers in sig. Patriot is making some noise as well with their ls6 and AFR's are considererd to be one of the best heads as well. Price wise it looks like ETP,AFR,TSP, Patriot most to less money wise.
Old 01-12-2006, 11:45 AM
LS1Tech Premium Sponsor
Jason 98 TA's Avatar
You have alot of choices when it comes to cylinder heads.. We just recently finished up a brand new LS6 program that flows better than any other LS6 cylinder head I've seen on our bench. This program works well with smaller valves as well as larger valves. As a intro special we are offering the heads complete with LS6 springs & decked to your specs for $849 a pair! The standard valve setup moves good air & gives you the ability to upgrade to larger valves down the road or right off the bat.
I have flow data for just about every cylinder head we carry, PRC, ET, DART, Etc... Feel free to contact me for info on anyone of these cylinder heads! We only carry the best products & offer a 100% money back guarantee!
__________________
Jason
Co-Owner, Texas Speed & Performance, Ltd.
2005 Twin Turbo C6
404cid Stroker, 67mm Twins
994rwhp/902lb ft @ 22 psi (mustang dyno) www.Texas-Speed.com
Old 01-12-2006, 11:50 AM
99blancoSS's Avatar
$849!?!?! Thats just not fair man, I paid 1400 last summer. I'm telling
Old 01-12-2006, 12:06 PM
Here are some flow numbers from a 2.00"/1.55" ported head that is shipping to a customer today:
.100" 75 / 62
.200" 154 / 121
.300" 215 / 165
.400" 254 / 200
.500" 285 / 217
.550" 292 / 221
.600" 301 / 226
These are on a 3.905" bore using a clay radius. These particular heads are a set that come with stock valves and our Orginal Patriot Gold Dual spring kit. These are $1095.00 plus shipping, which is $30.00. So for less than $1150.00, you can get a great set of heads that will work well with your setup. Give us a call or shoot us a PM if you have any questions.
Old 01-12-2006, 12:12 PM
!LS1 11 Second Club
.100" 75 / 62
.200" 154 / 121
.300" 215 / 165
.400" 254 / 200
.500" 285 / 217
.550" 292 / 221
.600" 301 / 226
Which heads were these? What cc?
Old 01-12-2006, 12:15 PM
These are our 243 castings. The intake runner will be 227 +/-.
Old 01-12-2006, 12:21 PM
!LS1 11 Second Club
Thanks!
