do it yourself?
Old 01-15-2006, 01:19 PM
andypdbz's Avatar
Default do it yourself?
i tried doing a search w/o any results, but is changing the rearend oil something you can do at home?
are there any complications and would you need any help or should i just take it to a mechanic?
Old 01-15-2006, 01:33 PM
The Sad's Avatar
You should be able to do it yourself. I have with no problems.
Jack it up and get it on jack stands, take most the bolts out of the cover (leave a few top ones in) then pry the bottom away and let it drain. Seal it back up and refill.
Old 01-15-2006, 01:37 PM
blue01ta's Avatar
Make sure if you have an LSD you put the right additive in. You can usually take the waste oil to autozone or a place like that to get rid of it. It really isn't any harder than changing the engine oil.
Old 01-15-2006, 02:31 PM
andypdbz's Avatar
do i need a new gasket or do you guys just reuse what you have?
also how do you put the oil in there when everthing is bolted back up??
Old 01-15-2006, 06:41 PM
The Sad's Avatar
I actually put RTV on mine.
To fill it up, there is a plug (I think on the section that hooks to the driveshaft) that you pull then fill.
Old 01-15-2006, 07:24 PM
Carter Hays's Avatar
Get a couple cans of brake part cleaner, clean the vent area and the some of the grime off the housing.
Use a 3/8 extension to remove the fill plug. Once you look at everything, it will become clear.
Old 01-15-2006, 07:55 PM
cbrich's Avatar
I also use RTV (I use ultra black, or ultra copper RTV from autozone), just make sure both surfaces are clean, and run a bead of silicone around the cover.
Old 01-16-2006, 12:16 AM
andypdbz's Avatar
thank you, my car had 24K and i've put about 10K more miles and im pretty sure the rearend fluid was never changed, so i figure i do it now...
