Stroked N Blown Project
proven combo is a 408 (iron) with whatever power adder you want.
if you want your front end to be lighter go with a aluminum 402.
can't go wrong either way.
how fast ya looking to be?
so what is the big difference with going with IRON i know stronger but how much??? and i know its alot more weight. but where is the line when you decide to buy a IRON block, over a aluminum. if i buy a aluminum one are my hp goals out of reach?? how much bost can it take????
don't listen to nasty! its the fues that are talking not him
get an iron block for durability : for instance, if you ever blow a gasket under boost, you'll eath the gasket ( cheap), might ruin the head ( not that expensive to fix), but the iron block won't be as likely to be hurt (compared to an alu. block, which would be expensive to replace). plus in my opinion, they can handle a bit more heat than an alu. block and you could bore it out if you ever wanted to.
ahhhh its all good.............
I went with Iron for strength...... if i ever change Motors ill go back to a Alum. to save the added 90lbs the iron block added......
