View Poll Results: which rear gear oil is best?
redline
12
21.43%
royal purple
36
64.29%
lucas oils
4
7.14%
dinosaur(coventional) oil
5
8.93%
Multiple Choice Poll. Voters: 56. You may not vote on this poll
favorite synthetic gear oil
Old 01-26-2006, 08:31 PM
slowpoke96z28's Avatar
Default favorite synthetic gear oil
what have you guys had good results with? also, how often do you change the fluid. do you get an oil analysis done on your fluid?
Old 01-27-2006, 05:06 AM
99PontTA's Avatar
Mobil 1 is all i use anymore...its the best gear oil out there 75-90 if you drive normal....75-140 if yer a animal.
Old 01-27-2006, 10:40 AM
GregWS6&z28's Avatar
I like Lucas products
Old 01-27-2006, 11:00 AM
Ryan02SS's Avatar
.....X2
Old 01-27-2006, 04:25 PM
bad6as's Avatar
amsoil 75w90
Old 01-27-2006, 06:03 PM
Anyone Else?
Old 01-27-2006, 06:15 PM
GM Muscle's Avatar
I've been swearing by Redline Shockproof (heavy) in my stock Torsen. I never bother to send it out for analysis but I do pop the cover and check out the rear about once a month. It's holding up suprisingly well for the abuse it sees.
Old 01-27-2006, 09:06 PM
you still have the stock rear?
Old 01-28-2006, 10:05 AM
GM Muscle's Avatar
It has moser axles and a girdle/stud kit. Other than that, it's stock.
Old 01-28-2006, 12:20 PM
what kind of 60' times do you get?
Old 01-28-2006, 01:09 PM
GM Muscle's Avatar
Normally mid 1.40s with good track prep, mid to low 1.50s at street night. Should see some 1.30s with the suspension changes I'm making this spring.
Old 01-28-2006, 05:24 PM
'Bird Director
y2k_ta's Avatar
Location: Central Indiana Honors: 4th grade spelling bee contestant
I'm a Red Line user too
Old 01-29-2006, 12:30 PM
any six-speed drivers out there?
Old 01-29-2006, 01:09 PM
bad6as's Avatar
whats that have to do with gear oil?
Old 01-29-2006, 03:02 PM
autos dont shock the rear as much as M6s do. just because some one with an auto can cut good short times on a 10 bolt doesn't mean an M6 car can.
Old 01-29-2006, 03:21 PM
ULTIMATEORANGESS's Avatar
ive used RP and lucas.
Old 01-31-2006, 12:54 PM
GM Muscle, where do you fine redline oil at?
Old 01-31-2006, 02:13 PM
GM Muscle's Avatar
Summit Racing and Jeg's carries it.
Old 01-31-2006, 03:47 PM
ClaySS01's Avatar
m6 royal purple
Old 02-01-2006, 01:57 AM
black00TA's Avatar
ive had best results from Mobil 1 75w90
and of course the tube of posi additive.
GM calls for these cars to have rear-end fluid changed every 7,500 FYI
Quick Reply: favorite synthetic gear oil
