Y-pipe touching
Old 01-29-2006, 08:06 PM
Justg's Avatar
Default Y-pipe touching
I have pacesetter headers and a TSP y-pipe. The y-pipe is hitting on the cross member. Has anyone just removed it, or am I the only one that can't get it to fit right? G
Old 01-29-2006, 08:11 PM
SgtB's Avatar
do not remove the crossmember. just play with it some more and it will fit
Old 01-29-2006, 08:32 PM
jlashley2001ss's Avatar
yeah the TSP y pipes are known for "banging" underneath the car. Just work with it
Old 01-29-2006, 08:41 PM
Justg's Avatar
I got it to stop hitting the floor under the driver. Now the cross member is the only part it's hitting on.
Old 01-29-2006, 09:08 PM
Eatinstang4life's Avatar
take the cross member off and bend the center part out a little than you should be good.
Old 01-29-2006, 09:25 PM
Schweet97Z's Avatar
what did you do to get it to stop hitting the floorboard?....and ill have to agree with eatinstang4life....take it off and bend the crossmember...
Old 01-29-2006, 10:06 PM
BackinBlack02SS's Avatar
Are you talking about the tranny crossmember or the tunnel brace? You can remove the runnel brace, but do not attempt to remove the transmission crossmember.
Old 01-30-2006, 12:23 AM
Cstick's Avatar
I threw my tunnel brace away. But anyways my final fix was to put poly motor mounts in. I tried repositioning the y pieces but it got hard to twist them after the second or so attempt. I tried ovaling the pipe some in the area with no luck. I found that I would loose to much ground clearance to stop the banging so that is why I went with the motor mounts.
Old 01-30-2006, 01:02 AM
That's what she said...
TheBlurLS1's Avatar
Poly motors mounts = the ****.
If its hitting the tunnel brace, take that bitch off and chunk it. If its hitting the tranny crossmember, you need to beat/bash the pipe and adjust the system some more. 90% of the time, the pipes just need to be tweaked a little bit more
Old 01-30-2006, 06:57 AM
Justg's Avatar
the merge of the y-pipe is laying on the tunnel brace. I got the y-pipe to go around the tranny brace. It kind of seems to sage at the y merger.
Old 01-30-2006, 08:08 AM
peterock98's Avatar
My y pipe is also banging does this cause knock?
Old 01-30-2006, 08:55 AM
SgtB's Avatar
yes, it can trigger the knock sensors
Old 01-30-2006, 09:31 AM
peterock98's Avatar
How do you fix it?
Old 01-30-2006, 09:38 AM
TheBlurLS1's Avatar
Originally Posted by peterock98
How do you fix it?
Take it apart and adjust it would be my guess.
A possible easy fix is maby a poly trans mount. It has a bit of vibration to it, but it either goes away or grows on you, at least i dont hear it anymore. Less simple fix would be poly motor mounts, even though it would take alot more to put them in.
Old 01-30-2006, 10:18 AM
Cash Only's Avatar
My tunnel brace was banging too, so I used some longer bolts and 3/4" worth of washers for spacing. Still bangs!! So that causes Knock in the engine? Does the engine see that and back off HP?
Old 01-30-2006, 11:41 AM
mine isnt that bad.
Old 01-30-2006, 12:11 PM
UCNTZME's Avatar
Yes when the engine sees knock it backs off!
Throw the tunnel brace in the trash to get the y pipe from hitting the floor board you can tack a used valve spring between the y and the floor board where it hits!
Old 01-30-2006, 01:44 PM
anyways about the y hitting the floor board, Alls i did was pound the floor board up with a hammer it worked great no more hitting the floor
Quick Reply: Y-pipe touching
