Spal 16" extreme part # ?
I need a 16" fan and i heard the spal extreme high performance fan is the way to go,
I was on E-bay and i see the Spal 16" 3,000 cfm Fan it cost $189, the part # for this fan is 30102113.
OK and i found another one that is also a 16" spal fan and the part # on this one is 30100845 but it cost much more $320 , It looks exactly the same but says its a 3,100 CFM fan
I head the Spal part # changed from 30100845 to the new part # which is 30102113
But i am not sure now which one to buy , i want the best one for my car,
Let me know if you know anything about this
thank you for your help.
Part Number: 30102113
Previous Part Number(s): 30100845
Description: VA18 - AP70/LL/F - 59A
Retail Price: $299.95
from http://spalusa.com/
3000CFM. But it's 3.65" profile.
http://spalusa.com/fans/automated/te.../0845-2113.pdf
The low profile 16", Part Number: 30100400, has 2.05" pofile but is 1300CFM.
http://spalusa.com/fans/automated/te.../0400-0401.pdf
Spal Fans And Part Numbers
Spal fans are good for changing part numbers around, As i said before we tested that fan and for the extra money compaired to their 2300 fan is just not worth it in my opinion, Also note this fan cannot be bolted directly to a core. The fan blade sits just below the finger guard if you inted to put this right against a core then you will need the gasket kit they sell for that fan. Suggestion get a shroud together. Also tripac has a fan that is 17" and it is a 270 watt fan, trying to get them to send us one to test but as of right now i do believe that one is the ticket. Also note if you were to apply 2-12" 225 watt fans to a core for an f-body you would be way ahead of either one of the single fans
