370 LS1 + S78 = 1128 Rwhp
I just spoke with Jose and he said a 98 camaro with a 370, AFR heads, Fast manifold, custom turbo kit, and one of Forced Inductions S78 made 1128 Rwhp @ 6700 rpm and 994 Rwtq @ 5400 rpm. This was at 24 psi of boost. I don't know anymore info but though you boys would like to know.
We knew about his early last week and the car made 1078 Rwhp but it pushed the heads off, so they redynoed with a little less timing and it made 1128. Jose said that it was around 23 total timing at peak hp I believe.
Glenn
Glenn
wow impressive , but this post is a tease. more info is wanted!!
Hopefully Jose will chime in on the turbo. I know it is a t6 flange and I believe it has a GT42 cold side. It should look the same as Nasty TA's turbo, just different guts.
As far as the motor, unfortunetely I don't know. Maybe Jose will help us out.
glenn
Originally Posted by NA$TY-TA
bad ***... good to know............. im really looking at that S88 real hard now.........
btw, im still upset you ditched the 6 speed
Originally Posted by RealQuick
If tis S78 is the "GT-42 78T" then they are not going to make them a production unit according to Jose. If the S78 is different the one I mentoned above thne I would like to know pricing.
Its different then the GT42 unit.....
Jer... Im going to get mine running and see what she will do with what i have now but then ill go with the bigger one then the S78.... the S88... I know the S88 is $1899 if i rememeber correctly...
Kyle
LS1TECH Sponsor
These units use nothing internal from the GT42. The shafts in the GT42 are to small and would snap under the weight of the bigger wheels. As for the pricing. The base S70 starts at 1299, and they go up to 1899 for the S88. The S78 is only 1599, and the S80 is 1699.
Jose
Jose
