Driveshaft Out Of Balance?
Old 01-30-2006, 05:30 PM
RrCoX22's Avatar
Default Driveshaft Out Of Balance?
So went to a local driveshaft shop to get new U-joints and yoke for my aluminum driveshaft and they said it was bent and really was helpless to be worked on. So he told me that he could make a custom steel driveshaft that would only be 3 lbs. heavier then my stocker.... I bought in.
Cut to the chase... now when mainly on the freeway with this new steel driveshaft when I punch it for say 80sih to whatever it will start to vibrate and constantly thud as speed increases. He did say he balanced it... so is this just common with steel driveshafts to make this noise, because I never had this problem with my aluminum driveshaft.
Old 01-30-2006, 07:25 PM
CW00BlackTA's Avatar
From my experience, the steel shafts are more stiff and transmit more vibration and noise. When I swapped mine, I had significantly more vibration. Now I need to figure out exactyl what's causing it--a real pain. Not sure about your clunking noise. I went so far as to have my steel shaft completely rebuilt and prefessionally balanced--didn't make much difference. Still searching for the cause of the vibration but it's not my shaft or joints.
Old 01-31-2006, 06:43 PM
RrCoX22's Avatar
so no one else has this problem with steel driveshafts?
Old 01-31-2006, 09:39 PM
pasbonsimon's Avatar
my steel driveshaft vibrates at 100+ too- but no clunking
Old 01-31-2006, 10:14 PM
MattZ28's Avatar
A properly balanced driveshaft should not vibrate like that.
Old 02-01-2006, 05:40 AM
EPP
EPP's Avatar
The steel shafts do indeed transmit more vibration, but I would demend they rebalance it though or give you your money back. Bob
Old 02-01-2006, 06:44 AM
NOBR8KSS's Avatar
I have a 3" steel driveshaft from Denny's (weighs 14 lbs) and I got significantly LESS vibration than with the stock aluminum shaft. Maybe my stocker was out of balance or something.
Old 02-03-2006, 12:41 PM
5.7LoFuN's Avatar
i recently had my stock Steel Shaft balanced in an effort to cure vibration at 80mph+ speeds. The place i took it to balanced the DS and replaced the rear Ujoint. Its weird but it seemed to help for a lil while, but the problem seemed to come back...i know its crazy. Im thinking it has something to do with my pinion angle since i lowered the car. You are not the only one who has this problem there is an on-going thread in this forum about people with same problem https://ls1tech.com/forums/suspension-brakes/436736-vibration-highway-come-inside.html
Old 02-07-2006, 12:35 AM
Jimmy P's Avatar
My car used to drive real smooth at 80+mph, but since I added a chromemolly driveshaft from a local driveshaft shop, and a Spohn adjustable torque arm I am getting a a lot of vibrations at high speed.
Old 02-07-2006, 01:16 AM
RrCoX22's Avatar
ya i suppose you guys could call it a vibration but honestly as speed increases in seems as if the driveshaft is gonna tear off and go straight through the floorboard
Old 02-07-2006, 08:21 AM
LPTXZ28's Avatar
I have the same prob after my moser 12 bolt, BMR trak pak, and steel ds install. Mine is over 100 mph. I thought it was just me!!
Quick Reply: Driveshaft Out Of Balance?
