View Poll Results: Should i reuse my header gaskets
Yes
32
71.11%
No
13
28.89%
Voters: 45. You may not vote on this poll
Should i reuse my stock metal header gasket?
Old 01-31-2006, 07:24 PM
KilerTA's Avatar
Default Should i reuse my stock metal header gasket?
Well as you can see should i reuse my header gasket over again or get a new one?
Old 01-31-2006, 08:10 PM
SSU's Drunk Typing Whore
Lithium's Avatar
Depends.
If they look good to you still reuse them. If there is anything that you might think will cause problems later on buy some new ones.
Old 01-31-2006, 08:15 PM
CRL 01 SS's Avatar
A lot of people reuse their stock header gaskets. I put new header gaskets on for the hell of it.
Old 01-31-2006, 08:28 PM
ЯєŧąяĐ Єl¡m¡иąŧøя ™
orangeapeel's Avatar
I did new ones just cause they came with the header!
Old 01-31-2006, 09:04 PM
Ωmega's Avatar
Just get new ones...Cheap insurance.
Old 01-31-2006, 09:34 PM
blkbird's Avatar
Im not saying you have to, but I reused mine and havent had any issues. But like they said if they look like crap then just replace them. I am going to replace my headers again soon since I banged all up and I will replace the gaskets with new ones then.
Old 02-01-2006, 06:20 AM
blue01ta's Avatar
If you choose to replace them make sure you get the factory GM gaskets.
Old 02-01-2006, 07:28 AM
227Hawk's Avatar
Reused my stock and no problems in 3 years.
Hawk
Old 02-01-2006, 08:24 AM
black01_WS6's Avatar
I say it depends on mileage and wear on the gaskets. Most of the time you will be fine with the stockers.
Old 02-01-2006, 08:37 AM
LS1LUNATIC's Avatar
I bought new ones, $20 for peace of mind.
Old 02-01-2006, 09:25 AM
jmm98LS1's Avatar
My stock gaskets have seen stock manifolds, mac midlengths, and now pacesetter longtubes......no leaks whatsoever. Re-use them.
Old 02-01-2006, 11:00 AM
hardcorebob's Avatar
New ones to make sure you don't have to go back soon after to replace them.
Old 02-01-2006, 11:16 AM
BlackHawk T/A's Avatar
I re-used my 75k mile stockers and no leaks.
Old 02-18-2006, 10:49 AM
Lane's Avatar
Unless they're falling apart, or you have a jillion miles on them - reuse those suckers!
Old 02-18-2006, 10:42 PM
GuitsBoy's Avatar
yeah, assuming theyre in good condition, just reuse em
Old 02-18-2006, 10:52 PM
'Bird Director
y2k_ta's Avatar
Location: Central Indiana Honors: 4th grade spelling bee contestant
Gaskets are meant to be tossed....don't take a chance. Buy new gaskets. If this is your first f-body header install, then you'll soon find out why it's not worth the risk. Trust me, you won't want to have to pull them back off just to replace a gasket.
Old 02-18-2006, 10:58 PM
GuitsBoy's Avatar
I agree that its inexpensive piece of mind, but why spend money if you dont have to. Most of the gaskets on the LS1 are meant to be reused. Thats why there's engineered silicone gaskets instead of the old fashioned ones in the 98 ls1s. I feel the same thinking went in with teh MLS exhaust gaskets. Even if he does get a leak with the reused MLS gasket, what does it take, 20 minutes to pull the plug wires, remove the 6 bolts per side, slide out the old gasket and slide in the new ones? It dosnt require removing the headers by any stretch IMHO.
Old 02-18-2006, 11:13 PM
98camaroLS1M6's Avatar
I agree, stock stainless steel are the way to go. They will never blow out like the cheap paper gaskets.
Old 02-19-2006, 12:01 AM
pontiacfireTAWS6's Avatar
I do beleive that once pressure has been applied to the gasket, it is going to leak no matter what if you re-used it, it may not be noticable, it may be noticable. I would buy new ones to prevent loss of horespower, having to replace them again.
Old 02-19-2006, 01:00 AM
273sunsetZ's Avatar
Just don't use the paper ones. Every one I know that has used paper ones have had leaks. Just reuse the old, unless they were leaking before hand, or you damaged them somehow while uninstillation.
Quick Reply: Should i reuse my stock metal header gasket?
