FI head decisions
Old 02-01-2006, 08:12 PM
b727pic's Avatar
Default FI head decisions
Before I make a $$$ mistake, lets get some clarification from all the air pump experts.
I am getting conflicting info on the pro's and con's of high dollar Vs econo heads in forced induction (procharger) applications.
While absolute flow is a consideration, I don't want to be giving up too much torque in the normal "cruising" mode of operation.
So lets get to the chase. given that I currently have a set of OEM bone stock 241 castings.....anything will be an improvement. That being said someone explain to me the difference between a PRC or PP ported head flowing 307 CFM @ .600 and an ETP or AFR flowing roughly the same????
What driveability issues in the lower RPM bands??
HP / TQ differences for given RPM settings??
Old 02-01-2006, 08:48 PM
WS-Sick's Avatar
Flow isn't everything. The velocity of the heads is important as well. I'm not sure what the difference in velocity is between the heads you listed but I know the the deck is thicker on the AFR's and ETP's. A thicker deck can be useful under higher boost levels because the heads will resist lifting off of the block.
...HP and TQ output will be dependant on your overall setup.
Old 02-01-2006, 08:55 PM
b727pic's Avatar
Not looking to go exploring into the realm of unknowns......my boost levels for the time being will be around 10-11 PSI. Running that now on the stock 241 Castings.
As for flow, I have not seen anything published on the 243's offered by PRC and PP. not being an expert on the topic (obviously) I presume that it is the velocity as a result of runner size that will have the greatest impact on torque.
Old 02-02-2006, 05:56 PM
Bens3rdgen's Avatar
I don't know how it works in the FI world but AFRs and stock heads flowing the same @.600 lift will not always flow the same at say @.300 lift. Ive found usually the AFRs have better low end Tq. It depends on who does the porting but usually if you find someone good enough they'll cost just a little less than AFRs do anyway. Also, once you get your AFRs they can be ported further to increase the flow @ .600.
Again, I've heard that this all makes a lot less of a difference once yo've got a turbo, the gains are less. If your under 15psi, it just depends on how much less PP costs than new heads. What prices have you been quoted?
Old 02-04-2006, 01:25 AM
b727pic's Avatar
both TSP and PP have the 243 castings CNC with the valve upgrades at around $1200-$1300
Old 02-06-2006, 03:58 PM
Bens3rdgen's Avatar
My 195cc AFR cost $1800 w/o shipping. I think what you really have to ask yourself is, "Am I really gonna be happy with 10-11psi." If yes, than stock will be fine, if no, than your gonna what something with a thicker deck. Just my .02
Ben
Old 02-06-2006, 05:20 PM
Got Me SOM's Avatar
I'm probably going to go with a AFR 205 or something that ESP offers, my car's a street car so I want a lot of low end grunt.
Old 02-06-2006, 06:40 PM
80superbu's Avatar
Ben
Glad someone brought up this thread cause I've been debating new heads too.
At what PSi would the deck thickness really become an issue
and to the top with this thread
Old 02-06-2006, 06:44 PM
camrsz's Avatar
do the darts heads have a thicker deck?
Old 02-06-2006, 07:13 PM
80superbu's Avatar
I searched all through the Dart site and the ads on Jegs and Summit. There is no mention of a thicker deck.
Old 02-06-2006, 08:04 PM
Got Me SOM's Avatar
Since you can warp a head easily if you lift them, as good insurance I'd go with a thicker deck just in case it happens.
hard to say what psi but if i had to say I'd say anything over 13 psi. :dunno:
Old 02-06-2006, 08:12 PM
ddnspider's Avatar
Received 1,736 Likes on 1,297 Posts
id say unless your going all out on a race car or more than 15psi a thicker deck isnt a must.get good gaskets and heads STUDS are a must.My heads just got finished and while the AFR 205's outflow me by a few cfm's at max lift(.600) i OWN them at mid lift,which is where the valve spends more time.You dont have to spend +$2000 to get good flowing heads for a non racecar.The thicker deck is nice for high boost but unless ur detonation and/or running quite a bit of boost its not a necessity.i believe harlan ran >20psi with a normal deck head
Old 02-06-2006, 08:16 PM
Got Me SOM's Avatar
can't wait to put the afr's on my car.
Old 02-06-2006, 08:26 PM
ddnspider's Avatar
cant wait to get the heads,motor,turbo,tranny,guages on my car LOL
Old 02-06-2006, 10:35 PM
J&J Speed Shop's Avatar
I would recommend the AFR 225cc head to anyone going FI, there is no lose of low end grunt
Old 02-06-2006, 11:05 PM
LANCE ATKINSON's Avatar
My heads are agostinos and have 232 intake runners and made 600trq lifting @ 5krpm running out of fuel on a 347 w A small cam. I think on a blower app u can force the air in but need a good exhaust number to get it out with some big headers! So I wouldnt just forget about cfm numbers completely. Call information for cnc cylinder heads in pinellas park florida for some bad *** blower app heads!!! Only reason I have are is they were 800 bucks and new! Ask for Pete he will fix u right up!!
Old 02-07-2006, 08:10 AM
Phate's Avatar
LOL, if you want to make power and get quality parts then stay away from ARE/Autoworks.
Old 02-07-2006, 08:59 AM
white2001s10's Avatar
Your peak boost is likely to go down some with better flowing heads. Centrifugals only peak at the higher RPM where your cylinder pressure is already dropping, so you probably have little to worry about as far as lifting the heads with what you've got. I would think good gaskets and studs would be more than enough unless you detonate.
As was said it would probably be a good idea to get boost-specific heads with much more exhaust bias. A head with a D-port and enough meat to put in larger exhaust seats would be what I'd go for.
Old 02-07-2006, 02:38 PM
Got Me SOM's Avatar
AFR 225's for the win then.
DDNSpider is your car at a shop? Your in Melbourne right? I'm gonna make a trip out there sometime.
Old 02-07-2006, 03:05 PM
ddnspider's Avatar
No not yet,still waiting for the motor to be shipped.and getting some parts.Ill be hosting pics of the heads and coated headers soon.Itll be at Rick Cranes shop,you may know him?If you want ill let you know when i have everything and you can always stop by then and see all the goodies,lol.If not im friends with Norris and he'll be tuning it so we could always meet up then.
