Factory Clutch Life
All depends on how you drive your car. My '02 is at 69xxx on the original clutch.
Originally Posted by TRANSAM_2000
FOR YOU LS1 QWNERS THAT GOT THERER LS1 NEW HOW LONG DOES THE STOCK CLUTCH LAST BECAUSE MY 2000 TA HAS ABOUT 59,000 MILE ON.
it depends on how you drive clutch!
many people dont know how to drive, race, drag or launch manual cars.
I have all bolt on mods, and 92,xxx miles on my factory clutch on my 2001 z28.
I drive hard, race alot and drag race too. Its driven hard not abused which is a huge difference.
95K + on a 2002 stock clutch. The 01 and 02 f bodies came with the slightly stronger z06 clutch, but I dont know if they last any longer. Ive done my share of spirited driving with the car, and I downshift and engine brake routinely. I am getting to the point of flat out overpowering the clutch however. Once my ported heads go on I feel the clutch will simply not camp and hold between gears. Ive already had a few shifts result in slipping clutches, however the low rpm in 6th gear test holds just fine.
I had my 00 TA's clutch changed at 40k miles (driving it like a bat out of hell) and it wasn't slipping at all. After the mechanic took it off, he called me and said "Your clutch doesn't need to be changed. I took it out and it looks brand new. Do you want me to put it back?" I was upgrading the drivetrain to hold the extra load of power I was adding so I was getting the clutch install out of the way. My 02 TA has maybe 20k miles on it and no slipping, etc. I've heard they'll last a long time as long as you don't add a cam or use slicks.
