New Lifters?
New Lifters?
I am currently in the process of installing the LE2 package in my 97 WS6, but I was wondering if I would need a better lifter to go with this setup. My stock lifters are still in good condition, but I question if they will be able to perform as well as a aftermarket set.
Not sure what's in Lloyd's LE2 package, but hopefully your doing a bigger cam, if hydraulic which sounds like it is, definitely upgrade your lifters. You can do a search online for CompR lifters for example (several good brands out there), which explain in gory detail why you should upgrade.
i personally used morals (sp). they are about 4-500 bucks a set and are great. even a set of GM OEM lifters would be fine too.
