removing tb blade when porting
Is it a must to remove the tb blade when you port the tb? the reason i ask is because if all you are doing is removing the "bump" in front of the opening then why could you not just mask off the blade and port in front of it, it seems easier. and that way you would not have to dissasemble and reassemble the tb. I'm afraid that if i take it apart i wont be able to get it back together lol, is it that hard? thanks!
1 Post
well you should clean really well both ways, leaving the blade in really helps as a guide to keep you from cutting too far it, i even knicked my blade a few times cuz i was using a crazy *** aluminum cutting but and it did no harm
