where is your electric cutout located?
Old 02-14-2006, 10:50 AM
Captain InsaneO's Avatar
Default where is your electric cutout located?
I am considering an electric cutout but I want to place it where it won't interfere with ground clearance, and won't rub on the car's underbody.
Anyone have pics or can clearly explain where you have yours located?
Thanks.
Old 02-14-2006, 01:45 PM
That's what she said...
TheBlurLS1's Avatar
Most people place them in the I-pipe, right where it takes the bend upwards to go over the rear end, and rotate the flange/motor for max ground clearance.
Old 02-14-2006, 02:03 PM
2001NBMZ28's Avatar
Mine's under the rear seat, bring the electric cutout with you when you get it welded in for the correct orientation. Ground clearance shouldn't be an issue, unless your car is lowered.
Old 02-14-2006, 02:10 PM
It is lowered.
Old 02-14-2006, 02:32 PM
I also want to be sure it'll be worth it. I hear that on nitrous runs the gains are considerable.. like 20hp or so. Can anyone verify that?
Old 02-14-2006, 02:36 PM
Moderator
jimmyblue's Avatar
Gains are in proportion to how much of the total
exhaust restriction is downstream of the cutout,
and how much your intake/heads/cam/headers
are able to push down an open pipe. A stock car
sees a small improvement only at the top end.
The harder you breathe, the more not exhaling
through a straw helps.
Old 02-14-2006, 02:42 PM
I understand that.. it just appears that the gain on a nitrous car with heads/cam would be greater than that of a N/A car with heads and cam.
Old 02-14-2006, 02:45 PM
99zman's Avatar
where do most mount the cut out with a loudmouth, before the resonator or after?? any pics would be nice?? thanks
Old 03-06-2006, 11:56 AM
Italiano99's Avatar
I have LM too and am interested also!!!
Old 03-06-2006, 12:40 PM
you2slo's Avatar
I would assume before the resonator. If it was behind, there would be no gain since the air already went through the "muffler".
Old 03-06-2006, 12:55 PM
SUTTERERMAN85's Avatar
thats where mine is at
Old 03-06-2006, 03:03 PM
Italiano99's Avatar
so if I have a catted Y the single cuttout would be after my cats but before my LM resonator, right?
Old 03-06-2006, 03:34 PM
you2slo's Avatar
Yup!!
