Changing transmision fluid in a 6 speed?
I have a 98 Z28 M6. Where is the drain plug on the transmission at? Where is the hole to fill it back up? I can't seem to find it? Thank you
Kleeborp the Moderator™
Passenger side of the tranny, there are two plugs. The one at the bottom is the drain plug. The one about half way up the tranny is the fill plug (yep, they made these things idiot proof).
Now, if someone could point me to a good pump system to get the oil into that side hole, I'd be really happy
Originally Posted by MeentSS02
And where did you all get these mysterious pumps? I don't wanna pull my shifter just to change the tranny fluid
at your local autoparts store, go by where the gear oil is... if its not there, go look where the grease guns are.... its usually in one of thoes two places... most autoparts stores have them.
i cant do it that way with mine due to the exhaust.... id rather pull the shifter then mess with the exhaust... plus mine is easier to pull... (remember im a LS1 swap conversion, not a 4thgen )
