Camaro SS Owner
Old 02-16-2006, 12:30 AM
NightRider01's Avatar
Default Camaro SS Owner
Hi, first I would to thank you guys for letting me enter this great forum with some great cars. I first heard of this forum from some members that joined up in an ARCO gas station in Perris CA. After meeting a man with an SS that had CDE4LS1 lisence plate, and saw with what quality it was put together I knew this was the site to be in with an F-body. Now that I've pretty much kissed some ***, I would like to ask what cams do you guys recommend for a Camaro SS '01 6 speed with only an aftermarket exhaust, and chip. I want a cam that is not too aggressive, but making lots more power from what I have(I'm thinking from 15-20hp gain).
thanks.
Old 02-16-2006, 12:48 AM
Lucas'02SS's Avatar
You can probably get some good advice in this section, but what you really need to do to find this out is read this stickyhttps://ls1tech.com/forums/generation-iii-internal-engine/442508-so-lost-cam-done-tons-research-still-lost.html by jaberwaki, and look in the LS1-LS6 internals section for cam threads, or search it. Here are a few about cams for you to pick through.
Start with this one:
https://ls1tech.com/forums/generation-iii-internal-engine/327734-cam-guide.html
https://ls1tech.com/forums/showthread.php?t=442508
https://ls1tech.com/forums/generation-iii-internal-engine/454652-new-kid-cam-question.html
Hope these help you out!!!
Old 02-16-2006, 12:49 AM
THANKS for the help.
