View Poll Results: Would you spend the money for it?
Yes
58
72.50%
No
22
27.50%
Voters: 80. You may not vote on this poll
If there was a manual clutch setup available for LS1's would you buy it?
Old 02-18-2006, 06:39 AM
ЯєŧąяĐ Єl¡m¡иąŧøя ™
orangeapeel's Avatar
Default If there was a manual clutch setup available for LS1's would you buy it?
I hate the issues that I have with bleeding the clutch and having it stick due to slave or master failure. I would definitely buy one if it ever comes out. That is one reason I enjoy a Mustang.
Old 02-18-2006, 10:53 AM
DONAIMIAN's Avatar
Im happy with the hydraulics. Hate cable clutches.
Old 02-18-2006, 12:21 PM
Guy2626c's Avatar
i would agree will killer there. My bronco is a cable clutch and that gets quite tiring fast..
Old 02-18-2006, 12:59 PM
StangEaterSS's Avatar
i enjoy hydrualic clutches abillity to still be quite easy to push the pedal in even w/ a crazy pressure plate. but i have had numerous problems w/ my hydrualics. even w/ all updated ones and the drill mod it still acts up. if it became available, i'd prolly buy a cable clutch set up to eliminate these headaches.
Old 02-18-2006, 01:10 PM
BLK02TA's Avatar
I'd go with a cable just to elimate some of the headaches.
Old 02-18-2006, 03:40 PM
Krab's Avatar
I'd stick to the hydraulic set-up.
Old 02-19-2006, 01:14 AM
cantdrv65's Avatar
Post
Hell no! It would only add to the list of clutch issues for everyone....
Old 02-19-2006, 01:19 AM
chpmnsws6's Avatar
i'd go to cable. no more worries about hydrolics failing and when you pop the clutch, you know your not gonna have any issues. it sucks waiting for the clutch pedal to come back up to you
Old 02-19-2006, 05:23 AM
ЯєŧąяĐ Єl¡m¡иąŧøя ™
that was where I was going with this.
Old 02-19-2006, 11:08 AM
black_z's Avatar
I would do the cable setup. My hydraulic system has been a ******* nightmare. I have driven plenty of cable operated clutches and they arent bad at all. You really need to hit the gym if you cant handle a cable operated clutch.
Old 02-19-2006, 01:29 PM
TroubledWine3's Avatar
Definitely go with the cable. I drove my friend's 2004 GT with a King Cobra clutch last time I was home and WOW, it was amazing to actually FEEL the clutch.
Old 02-19-2006, 01:57 PM
chpmnsws6's Avatar
its alot harder to push down with anything more then a stock clutch like that though....... but still VERY worth it for use track guys. is one being developed?
Old 02-19-2006, 04:02 PM
BriancWS6's Avatar
I do like the feel of a hydraulic clutch. When I get out of either one of my buddies mustangs, 00 GT and 01 Cobra, I just love how easy mine feels compared to theirs.
On the other hand I hate it when the pedal starts to barely hover off the floor when I am in the middle of a streetrace or going down the track.
I am hoping that when I get the new Textralia installed that my problems will go away....time will tell.
If this doesn't remedy the problem and a cable setup became available then I would definately get one. I mean as much as I like the light pedal feel, I could trade that for a stiffer push and the damn thing actually doing what it's suppose to do.
Old 02-19-2006, 05:38 PM
smokeum99ta's Avatar
I won't do either a cable or hydraulic setup. I would like a rod style. Cables break and fluid breaks down and gets air in them.
Old 02-20-2006, 06:18 AM
edwardswb's Avatar
Smokeum said it before I could. But cable or rod would be the hell out of hydraulics. I don't have a problem with my left leg being more defined than my right. lol
Old 02-20-2006, 06:46 PM
Ferocity02's Avatar
Hydraulic > Manual
Old 02-20-2006, 07:57 PM
chpmnsws6's Avatar
same here, espeically if the trade off is no more dealing with this fluid leaking or getting hot and not working
Old 02-20-2006, 08:35 PM
jerflash's Avatar
how about using a lt1 style clutch, hydrolics, and bell housing
from what i understand they dont have near the problems we have with hydrolics...i have no idea why they had to fix something that was not broken in the firstplace
not to mention easy bleeding and slave changes...feckin gm
Old 02-20-2006, 09:18 PM
chpmnsws6's Avatar
ones a push clutch and ones a pull clutch
Old 02-22-2006, 10:35 AM
_HAVOC_'s Avatar
we definitley need a cable set up like the mustangs, I HATE the hydralics on our cars!!!!!!!!!!!!!!!!!!
