Head Gasket
Head Gasket
What is the thinniest head gasket that is recommended for stock unmilled heads and stock engine?
I was thinking of going with a Mr. Gasket Ultra-Seal (.026" thick compared to stock .050" thick)
How much will this raise my compression (what would the ratio be)? I will run 93 all the time but I do not want to worry about pinging or engine damage/premature wear etc.
Will my fuel mpg improve or get worse? If so by how much?
This is a daily driver so I want to do it right but would like a little boost as long as it is safe.
With a stock engine & cam will raising my compression actually hurt performance?
stock block 97z28. Will get a pcm tune after too. What should I tune to take advantage of the extra compression? How do tuners tune (like madz28 does) for premium gas and acheive a 5-7 rwhp gain? I have tunercat btw.
