Race Prepped 4L60E
Race Prepped 4L60E
Hey everybody, Does anyone know where I could find a race prepped 4l60e besides speedinc.com? I need one that can handle up to 600h.p. before I upgrade to a 400.Thanks.
i did have a race prepped 400 that i bought but it seemed like too much work too install, bolts didnt fit to motor, longer than the stock 4l60e, crossmembers didnt place right, it wasnt computer controlled, I would much rahter go with a 400 but I dont know what to but to make it work and all that stuff.
Originally Posted by BBBBadSS
I'm getting mine from FLT. Chuck said his level 4 4l60e will handle 600hp.
http://tciauto.com/transmissions/index.htm
Old Drag Racer
...and they probably also mean it'll handle that much power for only a couple of miles down the road or a couple of passes down the track. That's what I've run into anyway.
Originally Posted by Deeavi
TCI says that their Super Street Fighter will also handle 600 hp. I am considering buying one of them:
Hey man, I would check out FLT, not that there is anything wrong with TCI.
But there is a $2000 difference.
TCI Super Street Fighter: $3000.00 + no core charge
Comparable FLT transmission: $2650.00 + ? core charge
I call that about a $350.00 difference, not $2000.00, and then you have the core charge. I like to see comparable cars with these treansmissions to see which one is best. Probably not much difference?
371150 PART# 4L60E Super Street Fighter™ 1998-up F-body $3,878.71
NOW THIS THE BEST ONE THEY GOT!!!!
COMPARED TO
4L60E-4 Street Strip–Level 4
Price: $1850.00 (with Exchange)
Options
Vacuum mod kit: $120.00
Deep pan kit: $80.00 (n/a C-5 corvette model)
FLT performance pump
FLT sleeved input drum
8 B/W high-energy clutches in 3-4 pack
FLT beast shell w/bearing
B/W 29 element sprag
4L65 low roller clutch
Transgo HD-2 shift kit
Corvette Servo
Wide 2-4 band
Bushing kit
All solenoids
Internal wire harness
Spacer plate
B/W clutches
Seal & gasket kit
Filter
Updated accumulator pistons
Set end play to performance specs
Call Doug Ludwig or Chuck Johnson today at 630-350-7776 for more information.
Continental U.S. residents will receive free shipping for all retail sales on transmissions purchased during the month of February.
So if you add it up it's $2000 in difference. I don't think you had your facts straight.
COMPARED TO
Options
Corvette Servo
Wide 2-4 band
Bushing kit
All solenoids
Spacer plate
B/W clutches
Seal & gasket kit
Filter
