Adjusting Window
Old 02-24-2006, 12:19 PM
dodgerman's Avatar
Question Adjusting Window
I just replaced my passenger side window motor on my 99 Formula but I am having a hell of a time getting my window to align right. I know i need a new set of stabilizers, but the window is still not sealing perfect. It seems as if the regulator needs to be adjusted. How is this done? I see a few bolts that hold the regulator which have arrows next to them pointing down, sideways, and i think up. Are these for adjusting? Can someone please explain with some detail how to properly align window, the motor swap was easy but this is a pita. Thanks. ( By the way the window was not aligned right before the motor finally gave out)
Kurt
Old 02-24-2006, 02:13 PM
blueorb's Avatar
I think this is what you are looking for:
http://shbox.com/1/adj_window.html
I posted something relating to this and Jditlfm provided the above link.
Old 02-24-2006, 02:32 PM
dodgerman's Avatar
Thank you very much, just the info i needed. Have any idea if the torque specs are the same for a 99 formula?
kurt
Old 02-25-2006, 01:43 AM
Droopy8503's Avatar
hey wuz up?? well my driver window is now out of comission and i'm gonna by the motor to get her runnin again, but the thing is that the button is very loose!! is that a problem and is it easy to fix??
Old 02-25-2006, 06:59 AM
Fratsit's Avatar
Fantastic link!! Thanks. I am gearing up to replace both in my 99 and the windows in my 92 need adjusting.
Thanks again.
Frat
Old 02-27-2006, 08:27 AM
blueorb's Avatar
Did any of you guys try this yet? I still need to do this but just haven't managed to get around to it yet.
Wondering how difficult it is/was...
Old 02-28-2006, 04:52 PM
dodgerman's Avatar
The window motor swap is very easy, just follow the guide from the link posted above. The problem I have is that the rivets that secure the regulator to the inner door frame have dug into the fiberglass which allows the regulator to "slip" when lifting the window. I can not get a seal around the window because of this. Any suggestions? I am thinking to drill out those rivets and use a combo of bolts, nuts and washers...any info would be greatly appreciated.
Kurt
