replaced master car is still wont go in gear.
ok, well i replaced the master cylinder since i couldnt put the car in gear at idle. well that didnt work. Im able to drive the car if i start it in first and it drives just fine after that. Im getting the slave replaced tomorrow. if that doesnt fix it, any ideas what else it could be?
i am having the same problem like my 6th gear grinds when i am cruising around town but on the expressway it goes in fine and sometimes it is like impossible to put into gear i have no idea what this is if someone can help me out aswell that would be awesome!!!
Originally Posted by underatedT/A
same problem here its the ram clutch did you shim it? did you use a upgraded slave cylinder?
no, i didnt shim it. its been in the car for about 2-3k. it should've done that a long time ago if it was cause of the shim. im using a stock slave, nothing special. ill find out later today or monday. if worse comes to worse and i need a new clutch i may try the centerforce or the ls7/ls2 combo
