LPE High Flow Maf/LPE Cold Air Intake C-5 System
Old 02-26-2006, 11:15 AM
TECHHERE's Avatar
Default LPE High Flow Maf/LPE Cold Air Intake C-5 System
I have been running this for a couple weeks now and would like to show the forum here my results.
New from Lingenfelter Performance Engineering
"High Flow Maf Sensor"
and
"High performance Air induction system"
These 2 products joined together gained me over 18 rwtq and10 rwhp over the previous Ram Air intake System and 2004
Z06 MAF that I run on my 1999 Z06 project car.
The Intake design cam from the LPE C-6 system currently available from their website for the C-6-http://www.lingenfelter.com/Merchant...ateg ory_Code=
It has a few changes that will be done before production models will be available for the C-5.
The Maf sensor was derived from the engineering departmant at LPE.It is not yet available to the public but will be soon.The new Maf is a completely new piece that is a full 4" diameter and has a special sensor that does a wonderful job of calculating the airflow that the PCM requires for proper fuel mapping.This unit does require a completely new Maf table that is used in the pcm,It is not a plug and play model so tuning is essential for proper operation.
More coming!
Old 02-26-2006, 11:17 AM
TECHHERE's Avatar
After New LPE MAF and LPE Intake
Old 02-26-2006, 11:18 AM
TECHHERE's Avatar
Default LPE Engine Combo
http://www.z06vette.com/forums/showthread.php?t=84342
Engine Specs:
2001 Z06 Engine - 10,000 miles
LPE CNC Stage 2 Heads-2.02Intake",1.57"Exhaust
LPE GT2-3 Cam - 207/220 .571int .578 exh 118.5
LPE Ported LS6 Intake
LPE Ported Stock Throttlebody
LPE Hi Volume Oil Pump
LS6 Injectors
UnderDrive Pulley
Stock Waterpump
Stock LS6 Clutch
Stock LS6 Exhaust Manifolds
3"Random Tech High Flow Center Section/Xpipe
Stock Titanium Mufflers
LPE Prototype Intake for C-5
LPE Highflow Maf
Old 02-26-2006, 11:25 AM
00SS4780's Avatar
Nice numbers. I like it. Any produtions for the f-body?
Old 02-26-2006, 11:39 AM
TECHHERE's Avatar
Default Fbody
I don't believe so.The Maf will work though!
Old 02-26-2006, 11:43 AM
00SS4780's Avatar
Cool, thanks! I'll have to keep an eye out for it.
It reminds me of a mustang maf.
Old 02-26-2006, 07:33 PM
WILWAXU's Avatar
Nice! What size is the ID of the MAF sensor?
Old 02-26-2006, 07:59 PM
TECHHERE's Avatar
Default Maf diameter
It is 4"
Old 03-06-2006, 10:17 PM
WILWAXU's Avatar
Nice!
